Hi all,
I'm moving from Brisbane to Sydney soonish and I think some car stuff just needs to find a new home.
R34 SMIC $100 ( I think this was better than my HDi FMIC due to better response when I had stock turbo, definitely an upgrade from R33 SMIC)
R33 SMIC FREE
R33 series 1 (I think) ECU $80 (I think it's series 1 but it worked fine on my series 2 R33 for more than a year)
Stock R33 turbo $150 (minimal shaft play, no problems replaced with larger Apexi turbo, 141,000km on motor, 10psi boost for previous 2 years, includes stock lines and actuator)
post-23086-1266915741_thumb.jpg all of this
post-23086-1266915768_thumb.jpg turbine
post-23086-1266915804_thumb.jpg compressor looks schmick.
Ray LMGT2 wheels 17 x8 +35, 17 x 9 +38. $750 with tyres
Rear tyres 90%, Federal 595SS 255/40/17
Front tyres 40% mixed brand.
(All wheels have some gutter rash, 1 is missing a centre cap thanks to QR, one front wheel has a noticeable dent in outer lip - wheel functions perfectly fine, not out of round , I drove like this for ~10,000km and no vibration issues, quoted $200 to fix and machine lip - which I am not going to bother doing!. Alternatively could put new outer lips on both fronts and make 8.5" +29 - thought about doing all 4 wheels and putting slicks on) Yes the wheels are dirty, yes they can be cleaned up more.
dented front
dent close-up
other front
rear 1
rear 2
Much prefer pick-up at West End, Brisbane.
Pricing seems fair to me however reasonable offers will be considered. Extreme low-ballers both annoy me yet somehow make me laugh.
I am not desperate as my work is paying for all my stuff to be shipped with me to Sydney.
https://www.sau.com.au/forums/topic/309399-r33-gtst-parts-and-wheels-brisbane/
  • 1 month later...
I'm open to offers for the wheels and turbo.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...=STRK:MESELX:IT trade? im in brisbane also. [email protected] trade the wheels with a little cash my way so i can fix up the dent? [email protected] pm me
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
