Hey guys, I have a Silver S2 R33 Skyline in Sydney for wrecking. It's been hit on the front left so headlights, guards, bonnet etc are gone. Rest of the car is available though:
I can post anything, or pickup available in Sydney
Aftermarket stuff:
Splitfire coil packs SF-DIS-005, suit S2 R33 rb25det, R34 GTR rb26dett - $450 posted
Apexi AVCR (black) with blue/white text. Great condition, includes all solenoids and a few bits of paper with the box - $450
Apexi PowerFC to suit ECR33 - $1100 ono
Nismo clear indicators - R33 - $50
Z32 AFM (with plug) - $200
GCG high flow R33 turbo with HKS actuator. Good condition with minimal shaft play - $1200 ono
post-35556-1266923885_thumb.jpg post-35556-1266923951_thumb.jpg post-35556-1266923970_thumb.jpg
Sard 550cc side feed injectors - suit rb25, sr20. Include plugs. Good condition, removed from the car about a week ago - $450 ono
Catch can, fully sick chrome. Includes hoses! - $60
Tomei 256 in/ex poncams, 8.5 lift. Suits late '97, '98 S2 R33 (with the black CAS) - $750 ono for the pair
Catco hi-flow cat, suits R32 and R33 - $100
Tein height and damper adjustable Control Master Flex coilovers, suit R33 Gts-t.
Rears are still on the car so only fronts are pictured. Theyll be out asap - $1000 ono
Walbro GSS-324, 255 L/hr fuel pump in R33 cradle - drops right in! - $120
Front strut brace - $90
Trust Pe-2 3" stainless steel catback exhaust, suits R33, great condition (pickup only!) - $500 ono
HDI Front mount cooler FMIC. 600x300x75, 3" inlet/outlets - $250 ono
OS Giken adjustable cam gear, suit RBs - $120
Blitz FATT - full auto turbo timer, black - $50
Rear strut brace - $100
Stock/Nissan parts:
Engine stuff:
R33 5-speed manual gearbox. Good condition, shifted well / no crunching. car had approx 148k k's. Includes tail shaft + yoke, shifter, crossmember - $1200 firm.
Standard airbox + snorkel. Mounts at the bottom are a little bit cracked. I fixed one of them (see pic) good for clearing defects or whatever - $80
R33 alternator - $100
Engine Mounts - $80
Fuse box lid - $20
Washer bottle - $20
Radiator overflow bottle - $20
S2 Aircon Condenser - $100
S2 ABS unit/pump - $100
BM-44 ABS brake master cylinder - $75
GTR BOV - $70
Stock BOV - $40
Cam angle sensor, late '97 style (black CAS) - $60
standard turbo oil/water lines - $50
Exterior/suspension/driveline:
Front series 2 grille - $50
Rear 'Skyline' garnish (KR4 silver) - $50
Drivers side wing mirror (KR4 silver) - $50
Tail lights (KR4, silver) - $50 each
Boot with S2 spoiler (KR4 silver), pickup only! - $100
Rear bumper (KR4 silver) - $50
Standard side skirts, genuine (plastic, KR4 silver) - $100/pair
S2 indicator/fog light - drivers side, crack in the side of the housing - not that noticible - $50
Front Calipers - $270
Rear Calipers - $150
Front rotors, good condition - $50
Rear rotors, good condition - $50
Front lower control arm (left side only) - $70
Front upper control arms - $50/pair
Front hubs - $150/pair
Rear lower control arms - $50 each
Rear 5 stud hubs - $150 pair
Handbrake assembly & cables - $160 pair
Manaual (4.11) ABS diff - $250
Driveshafts $50 pair
Rear upper arms - $50
Interior stuff:
Drivers side window switch surround - $50
Passenger door motor - $50
S2 door trims, full set (front+rear) good condition - $100
dash + gearstick surround - SOLD
Glovebox - $30
Series 2 dashboard (with passenger airbag & panel) - $250
S2 Steering wheel with airbag - $250
Climate control - $50
S2 Front seats, good condition. Small wear mark on the drivers side where you get in - $180
Seatbelts, full set - $80 (will seperate)
Ignition barrel + door barrels + key - $100
Wiper & indicator stalks - $40
PM me if youre after anything :P
  • Replies 88
"Splitfire coil packs SF-DIS-005, suit S2 R33 rb25det, R34 GTR rb26dett - $450 posted"
If these fit the S2 RB25, they wont fit an RB26 will they?? S2 hasn't got a separate ignitor like S1 or RB20/26, i thought all RB26's had separate ignitors....im not 100% on this, just asking the question.
32 and 33 GTRs have the separate ignitor but R34s don't :ninja:
PM Sent
PM replied
Do want GCG :P just gotta try and scrape together cash...
No worries, PM me if youre keen.
Grille sold pending payment
S2 r33 coil packs are the same as the R34 GTR rb26
Hi was hoping you still have the drivers side power window switches and if so could i see a picture of the back as there is are different ones
I need the spec 2 with the white plastic backing NOT the black
Thanks
J
PM box cleared, was full for a few hours before
Hiflow, grille, cam gear sold
Don't have a aircon/heater blower fan do you?
Bolted to bottom of air box.
PM back if so. thanks.
Pm sent
PM Sent
replied
Thanks
J
Sorry mate I sold the drivers side switch already
pm sent
Replied
heya can u PM me a price for just the passenger front seat?
Sorry mate just looking to sell them as a pair at the moment
Im after stock suspension can ya help us out?
Sorry mate I only have the coiloivers
PM Sent
Replied
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
