i'd come along but i am having full ankle reconstruction so that will slow down my preparation abilities!
01- Donnan 32 GTR
02- Kat 32 GTR
03- Troy 33 GTS-T
04- Shell R34 GTT
05- Reece 32 GTS-T
06- Bob??????
07- Cejay 32 GTS4
08- A20089 R33 GTR
09- ZCR R32 GTS-T
10- Dave R33 GTS-T
11 - Melly R33 GTS-T
12 - Mag86 (Andrew) MR30 Ti (pending mobility /painkillers on the day)
  • Replies 179
I'll show up. Hopefully have my front bar fixed by then and i can put a for sale sticker on it!
01- Donnan 32 GTR
02- Kat 32 GTR
03- Troy 33 GTS-T
04- Shell R34 GTT
05- Reece 32 GTS-T
06- Bob??????
07- Cejay 32 GTS4
08- A20089 R33 GTR
09- ZCR R32 GTS-T
10- Dave R33 GTS-T
13 - Luke R33 GTS-t
I'll come along
01- Donnan 32 GTR
02- Kat 32 GTR
03- Troy 33 GTS-T
04- Shell R34 GTT
05- Reece 32 GTS-T
06- Bob??????
07- Cejay 32 GTS4
08- A20089 R33 GTR
09- ZCR R32 GTS-T
10- Dave R33 GTS-T
13 - Luke R33 GTS-t
14 - R33_ACT (Rob) R33 GTST
Edited by R33_ACT
Ok im in
01- Donnan 32 GTR
02- Kat 32 GTR
03- Troy 33 GTS-T
04- Shell R34 GTT
05- Reece 32 GTS-T
06- Bob??????
07- Cejay 32 GTS4
08- A20089 R33 GTR
09- ZCR R32 GTS-T
10- Dave R33 GTS-T
13 - Luke R33 GTS-t
15 - Michael R33 GTS-T
will be there wit the r30 if i can get it running brand new motor all i need to do is get the gearbox back on stater motor and plenium wireing etc etc etc..... I have this weekn to do my best I may just be a spectator though I hope I can have my girl there.....
Can someone reassure me that it doesn't matter that my car has been keyed and my front bumper has fallen apart? I just feel weird going to a car show without a show car =(.
you will be fine :( we're not really a "show car" type of club :(
and as for the front bar, there is nothing cable ties can't fix hehe
Im in too
01- Donnan 32 GTR
02- Kat 32 GTR
03- Troy 33 GTS-T
04- Shell R34 GTT
05- Reece 32 GTS-T
06- Bob??????
07- Cejay 32 GTS4
08- A20089 R33 GTR
09- ZCR R32 GTS-T
10- Dave R33 GTS-T
13 - Luke R33 GTS-t
16 - Nathan R32 GTS-T
01- Donnan 32 GTR
02- Kat 32 GTR
03- Troy 33 GTS-T
04- Shell R34 GTT
05- Reece 32 GTS-T
06- Bob??????
07- Cejay 32 GTS4
08- A20089 R33 GTR
09- ZCR R32 GTS-T
10- Dave R33 GTS-T
13 - Luke R33 GTS-t
17 - David R33 GTST
I wouldnt worry, my front bar is sprayed with a rattle can and my boot holes are covered with electrical tape.
Thanks for the reassurances.
Edit: Didn't read that properly the first time Trozzle. Carpet shampoo and then vacuum it out. If you can't be bothered just use a watered down kitchen degreaser and again, vacuum it out once scrubbed (with a sponge or brush).
Edited by Giveway
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
