yeh there vct, im just wondering about the whole flow capacity of them seeing as the silvertop's heads rnt the best at it.. did they fix this problem with the neo? If it flows like a 25neo then it could be a worth wild upgrade... im asuming its going to be pretty much the same as fitting an sr20ve head to an sr20det with oil feed line's etc
https://www.sau.com.au/forums/topic/309450-rb20neo-head/#findComment-5102584
They are shit...dont do it!!!!
Because i have one with Tomei 2.4 internals that i am looking at running....one day when i am in Australian long enough to enjoy.
I have Tomei solid lifter conversion that i will also use and i will run some R34 GTT Tomei Poncams. I have not put a NEO head side by side but it only runs 9.5:1 compression so it seem perfect for a 2.4L as when you increase the diam of the combustion chamber to suit the larger bore you lower the compression...so will work out well. I am a bit concerned about the stud pattern on the inlet side as i expect like the RB25 NEO head which does not accept R33 RB25 inlet plenums....the RB20 NEO will be problematic with inlet manifolds
https://www.sau.com.au/forums/topic/309450-rb20neo-head/#findComment-5102652
I would say yes there is difference.
NA R34 NEO RB20DE has 2 intake pipes for providing air into intake plenum vs R32 RB20DET with one. So stock RB20DET turbo J pipe with BOV won't work.
Here's the photo's -
Unless you run 2x RB20DET throttlebody, throttlebody cable, etc on the intake plenum????
NA R34 NEO RB20DE ECU should be retuneable with Nistune like R34 NEO RB25DET ECU.
This is the R34 NEO RB25DE head vs R34 NEO RB25DET head thread on Nico forums -
http://forums.nicoclub.com/zerothread?id=470719
Ports are bigger on turbo R34 NEO RB25DET head. R34 NEO RB20DE head is probably the same as R34 NEO RB25DE head that has smaller ports.
But with a bit of porting, etc, maybe R34 NEO RB25DET intake manifold might fit on R34 NEO RB20DE head????
Edited by SKYPER
https://www.sau.com.au/forums/topic/309450-rb20neo-head/#findComment-5102775
Looking at the difference between the 2's port size's kinda makes me question the de heads? Would it actually flow better going by the size or would it need abit of machining to get it up to scratch? Im actualy running a redtop 12 port head which again looks alot different to the ones pictured on nico..
Edited by Justa32
https://www.sau.com.au/forums/topic/309450-rb20neo-head/#findComment-5103140
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
