comes down to what you wanna do to the engine, whether you wanna stroke it or whatever.
it also comes down to whether you are on a budget or not. you would be best to work out what you want to do and then go from there, when it comes to getting power out of a NA engine you could spend alot of money to gain only a few kW's.
https://www.sau.com.au/forums/topic/309486-engine-rebuild/#findComment-5108851
where do you plan on buying the pistons from?
You can get genuine 50thou but you are not going to find them as they are discontinued and i cleaned the last ones out in japan :D
your only other option for a non turbo build is custom made pistons or finding stock pistons in good condition and putting sleaves in your cylinders.
http://www.skylinesaustralia.com/forums/87...erson&st=20
thats my thread, its only 2 pages and has a list on there for re doing the engine (not including valves, spring, seat etc) Also if your not doing the labour it will cost a stupid amount.
https://www.sau.com.au/forums/topic/309486-engine-rebuild/#findComment-5120443
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
