comes down to what you wanna do to the engine, whether you wanna stroke it or whatever.
it also comes down to whether you are on a budget or not. you would be best to work out what you want to do and then go from there, when it comes to getting power out of a NA engine you could spend alot of money to gain only a few kW's.
https://www.sau.com.au/forums/topic/309486-engine-rebuild/#findComment-5108851
where do you plan on buying the pistons from?
You can get genuine 50thou but you are not going to find them as they are discontinued and i cleaned the last ones out in japan :D
your only other option for a non turbo build is custom made pistons or finding stock pistons in good condition and putting sleaves in your cylinders.
http://www.skylinesaustralia.com/forums/87...erson&st=20
thats my thread, its only 2 pages and has a list on there for re doing the engine (not including valves, spring, seat etc) Also if your not doing the labour it will cost a stupid amount.
https://www.sau.com.au/forums/topic/309486-engine-rebuild/#findComment-5120443
