Hey forum just wanted to get an injector question answered. I have a choice between two sets of injectors both have the same flow rate one has the four hole spray pattern(nismo), and the other has the single hole spray pattern(jecs). What I want to know from you guys is which spray pattern would be considered the better one to have, Four hole style or the single hole one?
https://www.sau.com.au/forums/topic/309487-injectors/
Now here is the other part to the question. The nismo ones flow basically 540 at 90% duty cycle at 43.5psi while the jecs flow 570 at the same duty cycle and psi. Which set of injectors should I stay with? I was thinking the jecs cause they offer more flow at the same psi, which I figured will be more room for tuning and safety. What do you guys think? Running an aftermarket regulator to answer the question.
https://www.sau.com.au/forums/topic/309487-injectors/#findComment-5103562
both same resistance? the 4 hole, what brand is it? arart from nismo.. is it a denso, etc etc.
you will be able to make more power with the 4 hole ones as the stream is split in 2 and aimed at the back of the valves giving a better burn rather than spraying onto the port divider going all over the place..
https://www.sau.com.au/forums/topic/309487-injectors/#findComment-5105785
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
