Hi mates,
All parts removed from R32 RB26 engine with approx 80,000kms shown on clock, running great.
> Cam Shafts - $150
> 5 x Connecting Rods with Forged Pistons attached inc Caps and Bolts - $150
> Oil Pickup - $30
> Aluminium engine mounts (set) - $40
> Cam Belt lower pulley - $40
> Oil Sender unit c/w Water Cooler - $60
> CAS Aluminium Bracket - $25
> Cam Belt Idler/Tensioner inc Spring, Bolts, Nuts and Washers - $20
> Vacuum Tank - $40
> Vacuum/Boost/Water lines from underneath plenum - $50
> Auxillary Air Control Valve - $40
> Cold Start Air Bypass Regulator - $40
> Rear Main Seal Housing - $30
> Oil Pressure Sensor - $30
> ECU Water Temp Sensor - $30
> Intake Air Temp Sensor - $30
> Knock Sensors (set) - $80
> Thermostat Housing - $40
> Cam Gear Backing Plate - $50
> Dip Stick and Dipstick Tube - $25
Ive also got a heap of bolts and bits and pieces, so if you need anything like that just ask and I may have it.
Located in Melbourne, happy to post all items, just PM me with what youre after and your postcode.
Cheers,
Mat.
0400 558 030
https://www.sau.com.au/forums/topic/309515-rb26-engine-parts/
Hi mates,
> Cam Shafts - $150
> Oil Pickup - $30
> Vacuum Tank - $40
Cheers,
Mat.
0400 558 030
Hi Mat,
Are they GTR parts?
Thanks
pistons have no markings but build appears to be fully jap, they measured at an amazing 87.5mm, and considering there is only 4, theyre useless ;)
good for paperweights or ashtrays.
  • 4 weeks later...
oil and water lines for turbo's?
I have only the lines that bolt directly to the core of the turbos and mount off the comp cover. Nothing that bolts to the block. $20 for both.
  • 1 month later...
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
    • It's all the sound deadening, and extra shit piled into them, plus all the extra (even though it's thinner) material for crumple zones. I can't fathom in modern cars why they need canbus to the headlights, and why the headlights must be vin coded on some cars to the ECU, BCM, and security module! Especially when they claim it's for security, yet, the canbus at the headlights let's thieves steal the car in minutes, so even more cars are being stolen! The Mercedes Sprinter 907 vans. They're a huge van, but a "basic" van. Yet they have that many canbus networks, plus two Lin networks, AND an Ethernet network. Logging a single network alone of 8 byte data frames, and they will generate a 20mb log file in 5 minutes. That's one network, and I can't remember the exact amount, but there's over 10 full CAN2.0B networks in them. I'm not a fan of modern cars, oddly, more and more I hate DBW, and all the bullshittery the cars try and interfere with. But all that bullshittery adds weight, plus crazy regulations on crumple zones, plus, ever picked a modern seat up, half of them have like 4 electric motors in them and will weigh 30+kg each. Then all the motors for things like adjustable steering columns blah blah blah. And did I mention the sound deadening so you can even hear an ambulance right behind you even if you 7.2surround sound is off?
