hey guys had a few threads with parts all over the place...
But here they are holla at me and pics will be mms'd on request
so drop me a reply or pm with some digits for whatever your interested in and I'll shoot over a pic
• RB20DET Standard Turbo - $$170
• RB20DET AFM - $$140
• RB20DET STD Cams - $$60
• RB20DET STD Injectors + Loom - $$120
• RB20DET Intake Manifold Top + Bottom Half with gasket - $$100ono
• RB20DET Exhuastanifold - $$80ono
• OEM Inlet Turbo Pipe - $$25
• RB20 Crossover pipe w/ Std BOV - $$50
• RB25 Crossover pipe w/ Std BOV - $$50
• R32 GTST Dash Cluster (11x,xxxkms) - $$120
• RB20DET ECU - $$150ono
• RB20 Coil Pack Cover - $$40
• Splitfire SF-DIS-001 Coilpacks + Coilpack Loom + Igniter Pack - $$470
  Or Coilpacks - $$420
  Igniter Pack - $$50
  Coilpack Loom - $$30
• R32 GTR STD 16X8” Forged Wheels w/ 90% Pirelli Dragons - $$430
• R33 GTS25t 4x 16X6.5" Wheels - $$140 (needs new tyres)
• R32 GTST front seats Drivers + Passenger - $$240pr or - $$150ea
• R32 GTST RB20DET (bare long motor blown headgasket) - $$400ono
• Rear Wiper and Motor - $$80
• Genuine NOS® 10 lb capacity bottle with the NOS Hi-Flo bottle valve - $$250 Cheappppp (14lb just the bottle 24lb Bottle and Gas currently weighing 21lb)
• R33 GTst Front and Rear Discs & Pads Discs can do with Machining, Pads: Fronts 80% Rears 70% - $$100
• R32 GTst smic all pipes etc... - $$70
• Apexi Power FC Boost control kit p# 415-A001 consists of: apexi 3bar map sensor & harness (3pin Type suit rb26) and apexi boost solenoid, harness and vacuum lines - $$280
• Defi HUD display for use with defi link system - $$150
  http://www.defi-shop.com/product/concept/concept_top.html
• Exedy heavy duty cushion button clutch 3 months use $$250
• RB20 starter motor - $$80ono
• RB20 power steering pump with bracket (hicas) - $$80ono
• RB25 A/C Compressor - $$90ono
• 5x114.3 pcd x 4 15mm hubcentric spacers - $$70 pair or all 4 - $$110
• 2x Falken Azeniz RT215 brand new with stickers 235/45ZR17 - $$215ea - $$400pair
Plus others I haven't Got Around to yet pm'd and I'll check it out and get back to you all
Cheers
https://www.sau.com.au/forums/topic/309583-massive-parts-clearance-sydney/
  • Replies 63
Hey guys I'm happy to take offers with upto 30% less what I'm asking on most things so please keep the offers coming but please don't offend me like others and offer $100 for pair of brand new RT215s and $120 for splitfire coilpacks it's ridiculous and will be ignored thanks.
By the way have a pair of R32 GTR guards in black perfectly straight $600ono pick up only
R32 GTSt guards front pair $300ono pick up only
I'll update the price list with more parts and better prices when I have time pics mmsed on request...
  Igniter Pack - $$50
Cheers
hey mate do you still have the igniter? if you do could you send a pic of the plug ends to [email protected], just to make sure its the right 1 for me
hey mate still have it and I'll email pics shortly
hey mate still have it and I'll email pics shortly...
hi have you still got the rb20 powersteering pump for sale?
i can pick up.
Igniter Pack - $$50
• R32 GTR STD 16X8" Forged Wheels w/ 90% Pirelli Dragons - $$430
Cheers
hey guys just clarifying that the above item is a pair only and not a full set of four wheels and tyres
And Ill accept $400 or near offers
thanks
Edited by krayzie32
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
