hey guys had a few threads with parts all over the place...
But here they are holla at me and pics will be mms'd on request
so drop me a reply or pm with some digits for whatever your interested in and I'll shoot over a pic
• RB20DET Standard Turbo - $$170
• RB20DET AFM - $$140
• RB20DET STD Cams - $$60
• RB20DET STD Injectors + Loom - $$120
• RB20DET Intake Manifold Top + Bottom Half with gasket - $$100ono
• RB20DET Exhuastanifold - $$80ono
• OEM Inlet Turbo Pipe - $$25
• RB20 Crossover pipe w/ Std BOV - $$50
• RB25 Crossover pipe w/ Std BOV - $$50
• R32 GTST Dash Cluster (11x,xxxkms) - $$120
• RB20DET ECU - $$150ono
• RB20 Coil Pack Cover - $$40
• Splitfire SF-DIS-001 Coilpacks + Coilpack Loom + Igniter Pack - $$470
  Or Coilpacks - $$420
  Igniter Pack - $$50
  Coilpack Loom - $$30
• R32 GTR STD 16X8” Forged Wheels w/ 90% Pirelli Dragons - $$430
• R33 GTS25t 4x 16X6.5" Wheels - $$140 (needs new tyres)
• R32 GTST front seats Drivers + Passenger - $$240pr or - $$150ea
• R32 GTST RB20DET (bare long motor blown headgasket) - $$400ono
• Rear Wiper and Motor - $$80
• Genuine NOS® 10 lb capacity bottle with the NOS Hi-Flo bottle valve - $$250 Cheappppp (14lb just the bottle 24lb Bottle and Gas currently weighing 21lb)
• R33 GTst Front and Rear Discs & Pads Discs can do with Machining, Pads: Fronts 80% Rears 70% - $$100
• R32 GTst smic all pipes etc... - $$70
• Apexi Power FC Boost control kit p# 415-A001 consists of: apexi 3bar map sensor & harness (3pin Type suit rb26) and apexi boost solenoid, harness and vacuum lines - $$280
• Defi HUD display for use with defi link system - $$150
  http://www.defi-shop.com/product/concept/concept_top.html
• Exedy heavy duty cushion button clutch 3 months use $$250
• RB20 starter motor - $$80ono
• RB20 power steering pump with bracket (hicas) - $$80ono
• RB25 A/C Compressor - $$90ono
• 5x114.3 pcd x 4 15mm hubcentric spacers - $$70 pair or all 4 - $$110
• 2x Falken Azeniz RT215 brand new with stickers 235/45ZR17 - $$215ea - $$400pair
Plus others I haven't Got Around to yet pm'd and I'll check it out and get back to you all
Cheers
https://www.sau.com.au/forums/topic/309583-massive-parts-clearance-sydney/
  • Replies 63
Hey guys I'm happy to take offers with upto 30% less what I'm asking on most things so please keep the offers coming but please don't offend me like others and offer $100 for pair of brand new RT215s and $120 for splitfire coilpacks it's ridiculous and will be ignored thanks.
By the way have a pair of R32 GTR guards in black perfectly straight $600ono pick up only
R32 GTSt guards front pair $300ono pick up only
I'll update the price list with more parts and better prices when I have time pics mmsed on request...
  Igniter Pack - $$50
Cheers
hey mate do you still have the igniter? if you do could you send a pic of the plug ends to steven.31@optusnet.com.au, just to make sure its the right 1 for me
hey mate still have it and I'll email pics shortly
hey mate still have it and I'll email pics shortly...
hi have you still got the rb20 powersteering pump for sale?
i can pick up.
Igniter Pack - $$50
• R32 GTR STD 16X8" Forged Wheels w/ 90% Pirelli Dragons - $$430
Cheers
hey guys just clarifying that the above item is a pair only and not a full set of four wheels and tyres
And Ill accept $400 or near offers
thanks
Edited by krayzie32
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
