• R32 GTR STD 16X8" Forged Wheels w/ 90% Pirelli Dragons - $$430
• R33 GTS25t 4x 16X6.5" Wheels - $$140 (needs new tyres)
have you still got either set of wheels, if so what offsets?
still got em...
R32 GTR wheels are pair only
offsets from memory are definately +30 for GTR wheels
maybe +30 for R33GTSt wheels but could be wrong... Will confirm when I get home from work.
  • Replies 63
intersted in the R32 GTR STD 16X8” what condition are they in .
Just a reminder that above is pair only.
That said pm sent.
hey, interested on HD clutch if it fits my rb25 push type.
cheers.
Part number seems to be the same, in saying that I'm 100% sure it'll fit
that said pm sent.
Cheers
SOLD ITEMS:
SPlITFIRE SF-DIS-001
DEFI HUD
RB20DET TURBO
32 GTR WHEELS
IGNITER PACK
COILPACK LOOM
SOLD PENDING COLLECTION
R33 WHEELS
EXEDY HDCB CLUTCH KIT
STILL AVAILABLE:
• RB20DET AFM - $$140
• RB20DET STD Cams - $$60
• RB20DET STD Cams Gears $$40
• RB20DET STD Injectors + Loom - $$120
• RB20DET Intake Manifold Top + Bottom Half with gasket - $$100
• RB20DET Exhuastanifold - $$80
• OEM Inlet Turbo Pipe - $$25
• RB20 Crossover pipe w/ Std BOV - $$50
• RB25 Crossover pipe w/ Std BOV - $$50
• R32 GTST Dash Cluster (11x,xxxkms) - $$120
• RB20DET ECU - $$150
• RB20DET Coil Pack Cover - $$40
• RB20DET Crank Angle Sensor - $$130
• R32 GTST front seats Drivers + Passenger - $$120ea
• R32 GTST RB20DET (bare long motor blown headgasket) - $$400 OFFERS
• Rear Wiper and Motor - $$80
• Genuine NOS® 10 lb capacity bottle with the NOS Hi-Flo bottle valve (14lb just the bottle 24lb Bottle and Gas currently weighing 21lb) $250 ONO
• R33 GTst Front and Rear Discs & Pads, Rotors good condition can do with Machining, Pads: Fronts 80% Rears 70% - $$100
• R32 GTst smic all pipes etc... - $$70
• Apexi Power FC Boost control kit p# 415-A001 consists of: apexi 3bar map sensor & harness (3pin Type suit rb26) and apexi boost solenoid, harness and vacuum lines - $$280 FIRM
• RB20 starter motor - $$80
• RB20 power steering pump with bracket (hicas) - $$80
• RB25 A/C Compressor - $$90
• 5x114.3 pcd x 4 15mm hubcentric spacers - $$70 pair or all 4 - $$110
• 2x Falken Azeniz RT215 brand new with stickers 235/45ZR17 - $$215ea - $$400pair FIRM
• R32 GTR FRONTBAR LIP Genuine (needs repair/plastic welder on one
Corner) - $$120 Ono Sydney only
• RB20 TURBO Actuator $$35
• RB FLYWHEEL $$50
hey mate is RB20 AFM green label? and good condition? if so can you pm pick up details thanks
yep, cheers for the quick sale and pickup henry
Coilpack cover posted to sa? ;)
pm sent bud
Nobody wants these items:
• Genuine NOS® 10 lb capacity bottle with the NOS Hi-Flo bottle valve (14lb just the bottle 24lb Bottle and Gas currently weighing 21lb) $$230
• 2x Falken Azeniz RT215 brand new with stickers 235/45ZR17 - $$215ea - $$400 pair
• Exedy Heavy Duty Cushion Button Clutch For RB Push Type (less than 6000kms plenty of meat) RRP $680 - $$250
SOLD ITEMS:
DEFI HUD
RB20DET TURBO
32 GTR WHEELS
IGNITER PACK
COILPACK LOOM
RB25 A/C Compressor
R33 WHEELS
RB20DET AFM
STILL AVAILABLE:
• RB FLYWHEEL $$50
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
