  • Replies 234
Posted Images
Just plug it into the OBD2 port and it will turn off with the ignition. :D
WRONG! lol sort of.
its not as simple as just plugging it in. if u plug red to red, the Touch stays on.. if you plug the Red to Orange, it will turn on n off with the ignition. make sure its red n orange.. u dont wanna short something. the orange wire plugs into your ACC power.
i think the ciggarette light is an addition to the non OBD readers..
Scott gave me the heads up before chopping. but yeh it says it in the book in the english part
mmm ... I don't think so ... I have had my Informeter working perfectly in my car for 6 months..
It is just called reading the Instructions.
maybe the later ones are wired different. i should take a copy of the book and upload where it says this
later models???
Back of the book in English it show's you.....you should have additional wiring attached to the plug....just plug and play. Mind you I have done mine different to Andy....I have a switch in between so I can turn it off and on!
Edited by Jetwreck
later models???
This is what my book says, i dont know if its different, not much point in buying two to compare lol
Says Red to Red, may drain the power because instead of turnin off with the ignition, it stays on, and after some time goes into stand by. not really good for your battery.
the image that says red to orange- it will turn off with the ignition. Notice it also says for NISSAN and subaru..
I dont know. ide rather follow the book. plus being a sound engineer, i know what damage power draining can do to battery cells, and units that are sitting in stand by for extensive times.
Craig- your idea of having a switch is pretty good. It would break the circut not draining poower at all..but what would be the reason to turn it off while your driving?
and one other question, My injectors hit 94% yesterday. should i consider bigger injectors? whats a forum for this infor for injectors that fit without plenum raising it(i like the cover so i wanna keep it)
cheers
Edited by AaronNM35
cheers
that's quite high....whats you AFM %?.....should be about 4.8%. You should start looking at doing the whole fuel pump, ECU and injector thingo! It's painful not having a car! :(
Looks like another Emanage install is in order. :)
Any of the 350z injectors will be plug and play. Plenty in the states on fleabay.
lol you really want me to put this emanage in dont you lol
ill have a look on 'fleabay' oh n what size injectors should I get 550cc will be enough? whats the stock?
i didnt take note of the air flow.. ill keep an eye on it driving home from work.. this means calm driving :( .
CRAIG GET A NEW ENGINE IN ALREADY!
n fuel pump? where the bloody hell am i gonna fit that.
Edited by AaronNM35
The second page of the instructions shows pretty clearly (IMO) that you connect Red - Orange on Nissan ODB cars and do not use the cigarette lighter.
94% injectors, nothing yet.. wait til you hit 100% lol.. You can set an alarm on the Injector so you know when you are in the danger zone. Mine is set at 95%. I usually only see 100% over 7000rpm.
What you need to know is if the AFR's are Ok. Get a Dyno run done to see what sort of tune you have going on.
Cheers
Andy
Cheers
Andy
yeh mines connected red - orange. Ok now Im confused about what the debate is on :( lol forget it, it works!
um yeh i have an alarm set for 95% aswell just so i pull my foot off the accelerator lol
hopefully the AFM% is at 4.8+- like craig says. other wise im fecked.
Dyno run? for a AWD? in Melbourne? ill have better luck finding a unicorn than to find someone who wants to do a AWD Dyno for less that $600.00 lol
motor is about a 2 weeks off! :)
Talk to Scott about the dyno when you get a second....wouldn't say you have a problem above 4.8....mine ran at 5.0 for a very long time....and that wasn't what blew my motor!
Hey, if I can get one done in Adelaide for $90 Im sure you can get one done in melbs :( Might be worth asking if the SAU:Vic chapter is planning a dyno day any time soon, good way to get a cheap run in for the sake of checking numbers if you dont wanna spend too much cash on it (SA dyno day was $40 for me (non member), same place would normally charge me $90)
Customs have my informeter, I think.. Bastards.
I pay $50 an hour now, and local... :(
yeh but does that guy still do it? i thought u said he left it n only doing urs.
craig- 2 weeks away is alright, at least this time you'll know to listen to warning signals. lol
Dunc - i'll get scott to help me find one, live 5 minutes from me. Customs? what do they think theres drugs in the plug or something.
Better hurry, he is selling the dyno soon. RE want $100 an hour now, what a rip.
RE's dyno is shit house aswell.. i remember seeing something about it being 20KW out or something.
$100 an hour for a useless company is stupid. i will NEVER take my car there.. a bunch of stuck up twats that dont know anything.
Sounds like you have been listening to Scott a bit too much there Aaron!
    • So these external kits with the machined block for remote solenoid mount will only work on a NEO head and RB30 or RB26 bottom end   For an R33 head on a 26 bottom end the remote vct kit is to resolve RB26 manifold adaptor plates etc  IF you try to use the remote VCT on an RB30 or RB26 bottom end with an R33 head then  you can starve the cam journal??? I have one of these kits from bits I had years ago before plans changed  I don't understand how that tracks with this video   https://youtu.be/RuPiI22Mplk?feature=shared   This looks like I can run the v termite vct kit to feed the VCT on an R33 head on an RB26 bottom end?!?!?   Lol.... don't v have these problems on RB20s
    • Yeah i know that MAF is no no for this type of BoV. The engine has no BoV and "hose/pipes" ..it was all deleted (or probably it was not even on the engine when it was bought  ) It does that "sutututu" noise which i kinda do not want(atmospheric is better IMO...but standalone ECU)  What are the cons of running without blow off on stock RB25DET NEO. It running 5-7 PSI max (it has boost controller)   EDIT: and can Nistune be "tuned" to know there is no BoV to i dont know "know" and be better for a car? I read so many info about no BoV. One guy saying it is bad and hurting the turbo/engine/car and other that it does not...
    • Yeah. OK. I'll say the same thing I say to everyone. You do not have to use 100% throttle all the time.
    • Mainly being afraid of breaking something on something i've poured so much money into haha
