PS will depend on weight input. Mine is set to 1800kg. It will only be accurate on flat ground too.
Water around 89
PS 545
Show off Scott.... lol
Water: varies.. but around 84 - 88 most days, on warmer days upto 94. (when you can see it vary it starts to get you worried)
PS: 281 (previous best on old turbo was 242, so arounf 17% improvement in power :rofl2: )
Injector Duty Cycle: 97% (@6800rpm)
Cheers
Andy
  • Replies 234
Posted Images
Water seem to sit around 87-94 depending on the temp of day
when its about 12 degrees outside my In-temp is about 18 degrees at full boost. 20 degrees outside sits at about 28 degrees
my max PS said something rediculous like 985 haha. So maybe my car is faster than scotts :rofl2: lol joking. it seem to be sitting around the 250 or near abouts.
Injection % is about 89% 6580 RPM. havent seen it hit 94% again,
how do I reset the maximums? so i can get a new figure?
Cheers
Andy
Sounds like your highflow is bang on the money, Andy. Must be pretty pleased.
my best PS is 200 ATM, all done up hill thoe,, havent had a chance to find a flat area long enough to crank it, running up coast today so will get it when i pull onto motorway, see how it goes
Aaron to reset peaks, select the bar graph or meter, select the middle option 'ITEM' then press the peak reading number, it will ask if you want to reset just that peak or all peaks,
awsome thanks, with the transmission hack that Scott did for me, i noticed PS increases, as does fuel consumption and injector %. just wanna see the differences.
should write down n post it. :rofl2:
If I give mine curry then stop intraffici hit high 90's. Highest I've been was 98 then darted down side street to get some air flow. Did a nice run up to mooney mooney for work, PS 239 on flat.
i have a nismo thermostat dude!
my temps didnt change from when andy tested the informeter on my car months ago. so i rekon the fan clutch could be screwed. can i buy your spare?? :ph34r:
I wouldn't be worried... I have see 96 in stop start traffic on a warm day. Mostly sits around 84-88 otherwise but thismorning was as low as 78 at times.
yeah i guess so, this morning it never went over 95, had the AC on all the way to the city in crawling traffic. i guess the thermo helped!
anyway, i got a blitz radiator cap to keep the pressure in there so it blows something else :ph34r:
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
