seriously.... ?
NO
pfft man i dont know. dont start another Spark Plug session. lol nah hers is stock, its probably just as thin as ours. might do some sourcing later on for an After market one.
  • Replies 234
Posted Images
When fitting a larger radiator, you need to cut the black "glassfibre composite" frame that it sits in
Ohh yeh like what Scott had to do?
should be too hard of a job right? In all honesty, what will the bigger radiator acheive? will this only make a difference if the cars tuned?
What do you think a larger radiator will achieve?
Better cooling control for one, especially when you consider that the stock core is only 16mm thick lol.
Not too difficult if you are happy to take to your car with a hacksaw.
I still had to hack up a fair bit to get my custom radiator in after I lost my nerve (and patience) with the Mishimoto unit that now resides in Scott's car
Edited by iamhe77
hmm.
16mm thick? more like you could fold it and make a paper aeroplane. i do see what you mean. is there a thread explaining this more? eg prices brands dimensions etc? might be worth looking into
hmm.
G35 radiators from the US... or a Z33 radiator that will need to be modified (cap needs to be moved and mounting "pegs" may need to be moved.
Make sure they have an in-tank cooler too.
That is all
For a custom one? I took my stock unit to Race Radiators who made me on up using a Griffin Race core and has them put the OEM in-tank into the custom unit.
Lovely unit and they do great work.
I still have my stock radiator if you want to go this route - but it will probably cost you more than buying a Chinese Z33 core and having it modified.
not really but we should start one on m35stagea.info
When you put yours in, feel free to put up a good "How to"... which reminds me, I really should do that transmission service post...
That is all
hmm might look at the G35's from us seeing as the dollar is still pretty good. its a pity no one has really made after market products for our cars :D
Has anybody gotten on to PWR and asked them to make something custom? with intanks and outlets n blah blah blah?
Edited by AaronNM35
hmm might look at the G35's from us seeing as the dollar is still pretty good. its a pity no one has really made after market products for our cars :(
PWR do a G35 radiator.
I spoke to them about a custom radiator and even measured up the stock one, but $1k + shipping with a possibility of it not fitting is not a risk I was prepared to take.
On the positive side, I believe that their G35 radiator retails for under $650USD... in the US, so should be significantly cheaper here you would think....
....BWAHAHAHAHAHAHAHAHAHA
Edited by iamhe77
what does the nismo thermostat open at ?
i know the r33's doesnt even think of opening until circa 79C anyway. more than likely the same principle applies.. meaning theres no flow around the engine until your hitting that temp anyway.
sometimes no thermostat is better.
im thinking 90C even though its not far off boiling temp.. isnt that far fetched for the running temp of this engine.
Edited by PetroDola
No thermostat, is almost always worse, car takes forever to heat up, if it ever does. Rich fuel mixture uses heaps of fuel, as you never get out of cold start map, washing oil off bores, allowing rings to score everything. Not a single good thing there...
Don't forget your cooling system is pressurised, water will not boil at 100deg, under pressure.
Edited by Daleo
good point!
im too used to working on older v8's daleo that dont have computers and run hot normally. so different principle i guess.
well then a lower temped thermostat should be sufficent then ?
Edited by PetroDola
I'm not really a fan of those either, in extreme cases they can cause similar problems to no thermostat, if the opening temp is low enough. You're only masking issues of an inadequate cooling system, either not enough water volume or not enough heat shedding ability. Both of which you can correct with an appropriately sized, well designed aftermarket core.
scott said to go where you went :( he said its a little more but they make sure it fits which i wouldnt mind spending the extra couple of hundred on, if that
Nismo thermostat opens at 68 degrees. The stock one opens at 78 degrees.
Cheers
Andy
on the nismo site it says it opens at 62c and standard nissan Thermostats open at 76.5c. I wouldve thought 62c would be abit cold right?
scott said to go where you went :down: he said its a little more but they make sure it fits which i wouldnt mind spending the extra couple of hundred on, if that
It is a little more that a Chinese unit, but they use great core's, workmanship is of high quality and a full custom radiator for just over $700 ain't too bad IMO.
PLUS I still have my old one which you can take to the to use as a template (to in-tank trans though - it is in my current radiator)
68c
I guess you were looking at a US site?
The Mishimoto VQ35 thermostat opens at 62c... which causes all kinds of issues for our cars, doesn't it Scott!
There are a few of us running the Nismo units with no issues whatsoever. Mine has been in for over a year and a half with no concerns :D
68c
There are a few of us running the Nismo units with no issues whatsoever. Mine has been in for over a year and a half with no concerns :down:
i thought i'de just have to give them the car and they make and install. using the one in the car as a template. i'm not too comfortable with doing something like the radiator by myself. i know it isnt a big job. but still new too it i dun wanna f**k anything up.
i duno it was a Nismo official site though. i wouldve thought if it was american they wouldve outlined temps in farenheit(or however its spelt) but they said 'C'
$700.00 for a radiator(for our car) i would be happy with. cant find anything for our cars easily or cheap .. whats IMO lol
Edited by AaronNM35
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
