It is a little more that a Chinese unit, but they use great core's, workmanship is of high quality and a full custom radiator for just over $700 ain't too bad IMO.
PLUS I still have my old one which you can take to the to use as a template (to in-tank trans though - it is in my current radiator)
68c
I guess you were looking at a US site?
The Mishimoto VQ35 thermostat opens at 62c... which causes all kinds of issues for our cars, doesn't it Scott!
There are a few of us running the Nismo units with no issues whatsoever. Mine has been in for over a year and a half with no concerns :down:
What was the difference in average running temp once you went to the Nismo, Cam?
  • Replies 234
Posted Images
Andy would probably be the better one to ask for a figure Dale, I can only go by the stock gauge which is a little lower than when using the stock thermostat.
Of course if I had an Informeter, I would have a figure for you - thus referring the question to Andy (as he brings this thread back on topic :down: )
I didn't really have the Informeter on my car till after I changed the Thermostat BUT I put the Informeter on Iain's car and for the same sort of driving his car ran about 5-8 degrees warmer from memory.
8 deg is a worthwhile difference, might have to do a bit of research once I have my "christmas" informeter. The weather will be conducive to a definitive result by then.
lol christmas informeter.
Andy are you running an after market radiator(sorry if i missed that)
http
;) /www.rhdjapan.com/nismo-low-temp-the...at-rb-vg-10002
only one i could find. doesnt say anything for our engine.
try this mob (but I noticed it is on back order)
http://www.z1motorsports.com/350_g35/produ...307dc078d2d7484
Cheers
Andy
i thought i'de just have to give them the car and they make and install. using the one in the car as a template. i'm not too comfortable with doing something like the radiator by myself. i know it isnt a big job. but still new too it i dun wanna f**k anything up.
i duno it was a Nismo official site though. i wouldve thought if it was american they wouldve outlined temps in farenheit(or however its spelt) but they said 'C'
$700.00 for a radiator(for our car) i would be happy with. cant find anything for our cars easily or cheap .. whats IMO lol
how much were the nismo thermostats and were they easy to source ?
i got a chinese knock off that was complete alloy very thick core from ebay for $212 delivered for the r33 (which worked awesome btw and looked great) - sure ok the r33 is as common as dogs balls but -
surely someone out there does a g35/v35 similar radiator?
ebay is your friend for this stuff :-check it
http://shop.ebay.com/i.html?_nkw=Infiniti+...ator&_rdc=1
aaron - IMO - in my opinion.
Edited by PetroDola
1. see the link in my previous post for the Nismo thermostat (ebay motors may have them also for 350z)
2. We have covered it in another thread, but be very mindful when getting a radiator from the US. They state "Z33/G35" but they not the same item. You NEED a G35 unit and NOT a Z33 (unless you are willing to get it modified)
Z33/G35 radiators from China appear to be pretty close to ours. when i say pretty close, i mean nothing like ours :)
A Z33 unit needs PLENTY of modding, a G35/V35 doesnt need much at all. best bet is to get one with the transmission loop already in it.
That said, it will fit with some cutting of the radiator support. its soft as shit, using a hacksaw blade and my hand did all the hard work on mine.
also, my water pump/viscous fan is poo. temps hit 98 on the freeway, and slowly dropped to 82ish and back up and hung around 90. too weird for me. Im going new pump and trying another fan clutch i think!
Z33/G35 radiators from China appear to be pretty close to ours. when i say pretty close, i mean nothing like ours sad.gif
good to know!
so you actually got one in the end ?
yeah mate i did
had to have it modded slightly - thanks to jetwreack for organising that - to get it similar enough to the stock one.
ill install over the xmas break
might buy a water pump while its all off too. im worried soething is wrong, car hit 104 yesterday in 29degree temps with the AC on :(
That water temp does seem high. When you have this sort of temp is your factory gauge also higher than normal?
I recon you probably still have a small air lock in the water system. It is a bitch to bleed.
Cheers
Andy
when you bleed it .. are you also letting off the radiator cap and the bleed valve in that order? bearing in mind they both hold air!
otherwise the trapped air in the top tank.. just feeds back into the block creating another air trap and around in circles you go. hehe. until the 10th time the air is finally gone.
best to run it with the rad cap off until it hits thermostat temp youll notice from the water starting to rush in the top tank also..another trick i learnt from working at a radiator shop..is youve got another radiator core most people forget about.. the heater.. so turn the heater on whilst running it with the rad cap off to refill that heater core and the water level will drop again fill it to the top.. recap it... then do the bleed valve for any excessive air.
you can as i did let it run for a good 45 minutes just idling with no radiator cap on.
refill at the end..then bleed valve until you see no spurts of air just water. then reseal with the heater on of course.. and youll find theres no more air and a filled tank that shouldnt drop ever unless its leaking or natural evap that draws from the overflow.
Edited by PetroDola
    • Me, I would happly spend some more coin on better tyres for my street car  Will they work, yes, of course, but why substitute some dry grip/braking distance, and wet weather grip/braking distance on what is really old tech to save some coin on your "precious" street car In the end it might not be you that farks up, it's the thousands of other idiots on the street that you need to worry about  For a street car that gets some "fun time", I have found that a quality tyre that can handle dry, wet, cold (Canberra gets pretty cold) and hot conditions, which may costs a little more, is great insurance  From my experience with them (driving around Goulburn in the winter) the RE003's are pretty poor in cold and/or wet conditions on the street If RS4's didn't hate gripping in the cold I would be running them always on the street,  great in the dry, OK in the wet, but, they do hate the cold, with a passion, I run PS5's year round now, basically, I've found the PS5 to be a great year round street tyre for all conditions, they last well, and are mid range pricing wise TL;DR. Tyre choice is probably like what brand and grade oil you should use, ask 10 people, and get 10 different answers... LOL
    • Extend the sensor out of the car, put it in a pot of oil, heat oil up. You'll get to 80-120 then 馃槢
    • Yeah - I tried throwing the formulas from ChatGPT and it tried it's best as it told me that the Formula in HPTuners as requested is a Linear function, but the original data I provided it (resistance to temp) is not linear and thus it kept trying to suggest formulas that would be more accurate in regions I actually want it to be accurate in. But I didn't quite understand it at the time. I have now thrown the data into graphs and can clearly see they're all different shapes. Given it's an oil temp sensor I probably want it to be most accurate between 80 and 120c - So I don't really see much alternative other than driving the hell out of the car and letting it cool down from 120C, noting the voltage on the sensor as it chills out. But at that point if I write it down, well, I'll be able to know this from the voltage. Would look pretty stupid on a datalog or a video showing me going down the straight at 0.265V Oil temp
    • Yeah, it looks like it's being ran as a constant current setup is my guess. Get some more data points, reading the degrees C on the gauge, and what the voltage is you're seeing out of it. The sensor itself is not linear, even in smaller ranges of like 20 - 60 it's non linear. But if we can get some good plots, particularly at those 5volt steps, it will be very easy to work out, and then I can give you a logarithmic formula if its you need an actual formula. Also, very likely ChatGPT will lead you astray with some of this stuff, as it totally depends on how the circuit is built.
    • So to further complicate things or hopefully explain better: This is a VDO sensor. It clearly does this math inside the gauge itself... because it displays a temperature in C to me instead of a voltage. The signal wire to the gauge is in Volts, not Ohms. I have just teed into this and sent it to the ECU. ChatGPT spat this out: Temperature (脗掳C) Thermistor Resistance (脦漏) Voltage Output (V) -40 36563.56 4.973962698 -35 26284.63 4.963854097 -30 19149 4.950518086 -25 14127.68 4.933166097 -20 10504.68 4.910527969 -15 7721.35 4.879055954 -10 5720.88 4.838133512 -5 4284.03 4.786165799 0 3240.18 4.721119717 5 2473.6 4.640900563 10 1905.87 4.543692515 15 1486.65 4.429695182 20 1168.64 4.296344225 25 926.71 4.144091368 30 739.98 3.972492431 35 594.9 3.782907287 40 481.53 3.577860996 45 392.57 3.361217186 50 322.17 3.136573398 55 266.19 2.908608143 60 221.17 2.68039363 65 184.72 2.455599277 70 155.29 2.239608872 75 131.38 2.035132288 80 112.08 1.846579676 85 96.4 1.674774149 90 82.96 1.511882199 95 71.44 1.359001674 100 61.92 1.222169588 105 54.01 1.100403407 110 47.24 0.989775394 115 41.42 0.889528391 120 36.51 0.800974069 125 32.38 0.723478416 130 28.81 0.654148313 135 25.7 0.591893137 140 23 0.536380597 145 20.68 0.487551867 150 18.59 0.442640126 155 16.74 0.40213318 160 15.11 0.365841848 165 13.66 0.333073247 170 12.38 0.303758956 175 11.25 0.277572169 180 10.24 0.253917873
