[mad33]
[fat33]
[dshi7] (dshit)
[bada55]
[line]
[skline]
[notgtr]
[no Gtr]
[beasty]
[sekcas] (sexy As)
[mine]
[not Urs]
[race U]
[raceya]
[raceme]
Etc Etc Etc.......there Are So Many....just Use Ur Imagination....im Sure A Lot Of These Have Been Used But There Just For Ideas
https://www.sau.com.au/forums/topic/30964-custom-plates/#findComment-625159
PMPN33 goes off!
MAD33
SIKR33
YTRY
ENVYME
NVMEEH
DRAGME
PWRFUL
TURBOD
LETSGO
SKMYDK (Suck my ....)
200HP (Or whateva HP u got)
SKYLNE
SKY HI
SKY HY
SKYLNR (Skyliner)
2PHAT
OWN YOU
ATLITS (At lights)
STUNTN
DRAG IT
https://www.sau.com.au/forums/topic/30964-custom-plates/#findComment-625254
Hope this helps buddy, cheers... sock.. :P
KUSTOM
GUY2NV
SKY4ME
HOLY
DIFRNT
IBITE
EVL666
11SEC
12SEC
10SEC
TUFAST
2FAST
TABO (Turbo)
MR R33
NISMO
DRIFTR
SLIDER
BADR33
QIKR33
RDY4U
BUSTED
SXYR33
TUR80 (Turbo)
NISN33
GLAMOR
0RGSM
TULOW
2LOW
LOWER
THRUST
B00ST
BOOST
BOOSTD
OBSESN (Obsession)
DVS R33
DVS KID
CORUPT
KORUPT
PILLZ (Pills)
MORE
PMPN33 goes off!
MAD33
SIKR33
YTRY
ENVYME
NVMEEH
DRAGME
PWRFUL
TURBOD
LETSGO
SKYLNE
SKY HI
SKY HY
SKYLNR (Skyliner)
2PHAT
OWN YOU
ATLITS (At lights)
STUNTN
DRAG IT
P1MP
BLOW ME
ZOOM
UWISH
GETLOW
SICR33
MR DVS
TUBAD (Too Bad You Lost)
FLORIT
QUIK33
NICE1
CAL000 (Call 000)
CAL911 (Call 911)
HOT 33
YUM R33
YUMIE
FANTAC
LOONY
POWAA
HRSPWR
TUGOOD
2GOOD
HORNE
HORNI
MUNEY
CASSH
NFNBTA (Nufin Betta)
DRUGZ
TURNON
SUKSHN
COKANE
NASTY
LUXURY
IHURTU
DANGA
QIKGTR
QIKGTT
QIKGTS
MADNSS
PAIN
BADASS
BADGTT
BADGTS
BADGTR
OUTLAW
DSIRE
HUSLR (Hustler)
ALLMYN (All Mine)
4RACN (4 Racin)
KMICAL (Chemical)
SINFUL
IDOSIN
W00T
HYPER
RVSPM (R.M.P)
REVIT
IM2HOT
RUWET
JEBUS
URGOD
BIONIX
BBRRMM
FLAME
FLAMN
GETRDY
HRD4U
4PLAY
MOVEHO (Probably Blacklisted)
WANTD
UP4MDR (Up 4 Murder)
SOHOT
COUPE
GESWHO (Guess Who?)
NVTHIS
REDR33
BLUR33
BLAK33
SLVR33
YELLO
XXXFUN
RUHOT
IAMHOT
IISHOT
MYPLAC (My Place)
STOCK
STOK
SEXBST (Sex Beast)
HORNEE
BIGONE
12INCH
TULOUD
2LOUD
MMMHOT
CMY33
CMYR33
OHYEH
USOOK (You Sook, I BEAT YOU!)
DNTCRY (Don't Cry Because I Won)
DWN4U (Down 4 You)
EXTASY
TASTY
TASTI
PARTY
PARTYY
WHYNOT
BURNIE
AWD4ME
CRUZE
CRUIZE
CRUZN (Cruisin)
TOMATO (I Want this plate so dont take it :))
NOMORE
13INCH
IMLOW
LOWA (Lower)
DOGGY (Doggy Style)
DOMEEH
DO IT1
SHODOG
FOSHOW
FOSHO
WOMMM
BLOOFF (BOV)
CLASSY
PIG H8R
DEFECT
DFCTVE (Defective)
RUNXT (Are You Next)
GRUNT
SIX CYL
5 SPEED
6 SPEED
SKMEH0
2RUDE
NAUTY
NAUTIE
PLAYA
PLAYAZ
WNKSTA (Wanksta)
TRYN4U (Tryin 4 You)
DEALER
RING ME
SUK ME
USKBAD
COMPLN (Complain)
IMA CON (Con Artist)
CON ART
LUV YOU
ORGSM (Orgasm)
BLADE
BEERZ
SOCKZ
ORG13 (Orgie)
CARBON
KARBON
XDRIFTR
SHUT UP
SOKOOL
SOCOOL
OMG R33
MYNS33
STIKY
HAPPY
WUSSUP
WASNME (Wasnt Me)
STOLN
STOLEN
SIX66
MOMO1
MONAY
IM RICH
PWR2ME
WUTELS (What Else)
SAU4ME (Skylines Australia 4 Me ;))
SAUCEY
SAUCY
SAUCE
SAUCI
ONRUN (On The Run)
HUNTED
HELLO
SKYSUP
MYGTST
NIZMO
MODDED
LETZROL (Let's Roll)
BLAMEU (I Blame You)
SCARIE
ICYOU (I See You)
ICY R33
TRU R33
ILUV33 (I Love R33's)
ZOOOM
THRUST
13 PSI
14 PSI
15 PSI
WHORU
SLEEK
URIDOL (Your Idol)
SEMEGO (See Me Go)
SM00TH
SMOOTH
POPIT
CYAL8R (Cya Later)
DISR33
THIS33
PI5UOFF (Piss You Off)
V8S LOL
BURNV8 (Burn V8'S)
UBLEED
NVDR33 (Envied R33)
UBTARN (You Betta Run)
FKYOU (F_ck You)
RUSNGL (Are You Single)
https://www.sau.com.au/forums/topic/30964-custom-plates/#findComment-625268
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
