Hey guys,
Got a problem.
As some of you might know the 1JZ only has 3 injector feed lines.
I'm currently trying to wire up the injector harness on the 1JZ but am unsure of how to do it.
I'm aware I need to double up the wires on the EMB
On the ECU pin out the injector feed lines go
Line1 Cylinders 1,4
Line2 Cylinders 3,5
and Line3 Cylinders 2,6
So when I double up do I wire it up
I/J CH-1 and 4 to #1
I/J CH-3 and 5 to #2
I/J CH-2 and 6 to #3
or
I/J CH-1 and 2 to #1
I/J CH-3 and 4 to #2
I/J CH-5 and 6 to #3
Cheers,
Benjamin
https://www.sau.com.au/forums/topic/309686-wiring-injectors-on-emanage-for-1jz/
Well this is interesting.
After some advice, I've now wired it up the ECU
EMB I/J CH-1 and 4 to #1 INJ ECU
EMB I/J CH-3 and 5 to #2 INJ ECU
EMB I/J CH-2 and 6 to #3 INJ ECU
and it won't start now.
It turns then dies almost straight away
Also I don't get why my interaction light is always lit orange without the USB cable connected
Perhaps it was suggested to wire like that for firing order? 1-5-3-6-2-4, so by having them paired like that, they'd be signaling ch1, ch2, ch3, repeat?
I too would like confirmation on that for my own knowledge :D I'm probably way off
Firing Order:1-5-3-6-2-4
As has been said: #1 inj driver to injectors 1 and 6
#2 inj driver to injectors 2 and 5
#3 inj driver to injectors 3 and 4
Not usre where you getting you advice from but I would cease listening to that person.
Edited by rob82
oh ok, fair enough.
Well its just that when I looked at the ECU pinout it made alot of sense to connect it the way I was advised
*sigh*
Wired it up this way. Did not start either.
Problem seems to have been solved.
Wired it this way again
and it ran lumpy.
Unplugged the EMB let the car warm up on the stock ECU then turned the car off and plugged in the EMB and now everything is fine somehow.
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
