Hey guys,
Got a problem.
As some of you might know the 1JZ only has 3 injector feed lines.
I'm currently trying to wire up the injector harness on the 1JZ but am unsure of how to do it.
I'm aware I need to double up the wires on the EMB
On the ECU pin out the injector feed lines go
Line1 Cylinders 1,4
Line2 Cylinders 3,5
and Line3 Cylinders 2,6
So when I double up do I wire it up
I/J CH-1 and 4 to #1
I/J CH-3 and 5 to #2
I/J CH-2 and 6 to #3
or
I/J CH-1 and 2 to #1
I/J CH-3 and 4 to #2
I/J CH-5 and 6 to #3
Cheers,
Benjamin
https://www.sau.com.au/forums/topic/309686-wiring-injectors-on-emanage-for-1jz/
Well this is interesting.
After some advice, I've now wired it up the ECU
EMB I/J CH-1 and 4 to #1 INJ ECU
EMB I/J CH-3 and 5 to #2 INJ ECU
EMB I/J CH-2 and 6 to #3 INJ ECU
and it won't start now.
It turns then dies almost straight away
Also I don't get why my interaction light is always lit orange without the USB cable connected
Perhaps it was suggested to wire like that for firing order? 1-5-3-6-2-4, so by having them paired like that, they'd be signaling ch1, ch2, ch3, repeat?
I too would like confirmation on that for my own knowledge :D I'm probably way off
Firing Order:1-5-3-6-2-4
As has been said: #1 inj driver to injectors 1 and 6
#2 inj driver to injectors 2 and 5
#3 inj driver to injectors 3 and 4
Not usre where you getting you advice from but I would cease listening to that person.
Edited by rob82
oh ok, fair enough.
Well its just that when I looked at the ECU pinout it made alot of sense to connect it the way I was advised
*sigh*
Wired it up this way. Did not start either.
Problem seems to have been solved.
Wired it this way again
and it ran lumpy.
Unplugged the EMB let the car warm up on the stock ECU then turned the car off and plugged in the EMB and now everything is fine somehow.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
