Next week I will be pulling some bits off my Stagea and will need to sell them asap to pay for my new bits so have a look at these as I will put them up for sale on here for a few days and then stick them on TradeMe as I will need to sell quickly:
GCG highflowed turbo (all new except for housing - steel wheels, ball bearings etc) rated at 450hp made 245awkw on my Stagea - straight bolt on replacement for S1 or S2 (or Skyline RB20 RB25) done about 10,000k (being replaced with GT3540) - $800
Z32 afm bought brand new (not from an old car) c/w used plug $200
Greddy (not cheap Chinese) adjustable exhaust cam gear $100
Postage would be about $20 -$25 anywhere in Au for the smaller items and about $90 for the turbo.
When I have them off I will put up a for sale with pictures.
https://www.sau.com.au/forums/topic/309691-eoi-gcg-highflowed-turbo-etc/
Good try! It cost me over AU$1800 (plus a stock turbo) so I think AU$800 is a fair price. I will confirm the price when i have it out of the car and can confirm that it is in good nick.
When did you get fullboost on this? Were you running aftermarket cams to get that power figure?
Have a look at my chart post# 372 http://www.skylinesaustralia.com/forums/St...html&st=360
The tuner had been fiddling with my IEBC - I fixed it afterwards and it holds 1 bar from 3000 - 7000 rev/min. The turbo is capable of more but I limited it to 1 bar because my engine was unopened stock.
To make this power you mainly need
1. a decent turbo
2. z32 afm
3. bigger injectors
4. either a bigger smic (nismo, trust) or a fmic
5. 3in turbo back exhaust
6. Some means of tuning the engine and a good tuner.
That's it really. You can have stock cams, fpr, bov ...I still have the stock airbox and snorkel (with a high flow panel filter).
I ran an adjustable exhaust cam gear which gives more midrange punch but no extra topend max.
I have changed the stock bov for a GTR one mainly as insurance.
The stock fuel pump should be upgraded - I have an intank Walbro and I am installing a surge tank and 2nd pump (Bosch) for the track
1. a decent turbo
2. z32 afm
3. bigger injectors
I've got a pretty good feeling that your manual box will be also aiding your power figure by a fair bit.
Can you please pm me BEST price of the turbo posted to 5066.
  • 3 weeks later...
Turbo sold to a member who first enquired about it months ago. Thanks to all who expressed interest.
Adjustable cam gear sold.
Z32 afm (bought brand new 5000km ago) now for sale at $200 - will put it on TradeMe for about $250 unless someone buys it before Sunday night.
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
