hi guys
ive got my nissan skyline R32 RB20det wich has modified to it so far a dump pipe, 48mm external wastegate, nismo tune, frount mount intercooler, 3inch turbo back exst. and im looking to put in some cams all ive found so far are the Nissan Skyline R32 RB20 Camshaft Poncam 256deg 8.5mm wich they say will fit standard RB20s but will love to hear from yous... also what else will i need to get to install these in eg. cam gears, solid lifters, bigger valve springs.......ect
your help will be greatly appriciated :blush:
https://www.sau.com.au/forums/topic/309758-rb20-cams/
They should be fine with standard valves, springs etc. But I do not see the benifit. What turbocharger is on the car, do you have any dyno figures? With the right setup you might not need cams.
I would say if you are chasing 300rwkw then it would be worthwhile, otherwise don't bother. There are plenty of good responsive setups (relatively) that can be had if you dont want anywhere near that power.
https://www.sau.com.au/forums/topic/309758-rb20-cams/#findComment-5106329
Worth the $$$.
For nearly half the cost ($400NZD + GST or cheaper in AUD), can get the stock cams reprofiled. Tomei Poncams are similar to reprofiled stock cams (said to have have the same knotches on cams for accessing headbolts), but I gather they use new copies (blanks that are made by Tomei) of stock cams that are reprofiled to spec and badged Tomei cams. I guess it explains why Poncams work with stock cam gears, stock valve springs if they are based off stock cams. Measure the base circle of lobes and compare base circle on stock cam lobes and you'll probably notice 1mm or so missing on Poncams vs stock cams to make profile of lobes more aggressive.
In NZ there's Franklin cams that can reprofile stock cams (mention duration of reprofiled "STD" (stock) RB20/RB25 cams and looks like there are 2 options / profiles for stock cams) -
http://camshafts.co.nz/Nissan.aspx
Or there's Kelford cams in NZ -
http://www.kelford.co.nz/regrinds
I guess good hp gains for $$$$ spent and some profiles work with stock turbo, stock ECU (I presume retuned stock ECU), stock valve springs, etc.
I wouldn't have a clue who does this reprofiling in Australia. But I bet there are cam company's that do reprofiling, which can save on shipping cost's.
Here's a link on bedding in new cams on Kelford website -
http://www.camshaftshop.co.nz/index.php/Ca...-procedure.html
I gather you have to buy new lifters / flat tappets with new cams, but I guess it makes sense when fitting new cams???
There's an article on the tappet failures, so it might not be the tappet, but the oil you use -
http://www.hotrod.com/techarticles/engine/...tech/index.html
Edited by SKYPER
https://www.sau.com.au/forums/topic/309758-rb20-cams/#findComment-5106915
um..... ive got just the standard RB20 turbo in it ( has not yet been hiflowed) and on the dyno its currently pushing out 234.9hp
https://www.sau.com.au/forums/topic/309758-rb20-cams/#findComment-5107030
Waste of time going cams until you need them.
360-380rwhp (boost dependant) here and I am starting to think about cams now. You have a long way to go yet :cheers:
Horses for courses however. I have seen 200rwkw RB20's that seem to respond well to cams although I am not sure if I personally call it a worthy investment.
https://www.sau.com.au/forums/topic/309758-rb20-cams/#findComment-5107088
hi guys
your help will be greatly appriciated :cheers:
what turbo?
https://www.sau.com.au/forums/topic/309758-rb20-cams/#findComment-5107116
Poncams work with stock or N1 turbo's on GTR. Tomei mention stock or N1 turbo's + Poncams on this webpage -
http://www.tomei-p.co.jp/_2003web-catalogu...0_cam_RB26.html
Wouldn't think it's any different with stock or hybrid turbo + Poncams / reprofiled stock cams for RB20DET.
Edited by SKYPER
https://www.sau.com.au/forums/topic/309758-rb20-cams/#findComment-5107640
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
    • Yes, a plan for non-action is always my first sort of plan! I'm happy to see what falls out of invision's update. I had been having some thoughts on what to do with this the other day and they all seem to have fled my memory, after various solar panel induced traumas, squeaking suspension sphericals, etc etc, over the last little bit. I'll try and recall what I had in mind and make sure that I put it into print in some form before the Alzheimer's strikes again.
    • The ability to have both a 5500 stall for launching, and a regular lockup for every other scenario is pretty sweet. Does it actually work well like that though in the real world? Would it hold up to track use and otherwise you'd never know you had a stall converter in it? If so, that's awesome
    • The thing is, once the content has been tagged we can chop and change the end result as much as we want. Its identifying the content in the first place that needs to be done regardless of the final outcome.
    • Sorry @GTSBoy I thought I'd replied here. There's a new BIG version of invision coming out soon, it might be worth waiting until that happens as it contains a lot of improved functionality for tags. My suggestion would be to add a top level page (not thread) with some info on it and then link to sub pages for various topics. We could even just start really simple with 2 or 3 pages underneath it. Those pages could just have a view (like a pre configured search result) of the tags we choose to put on it. We could have some background or an intro on each of these pages. My only issue is that while admins and mods can update the existing content to contain the tags we want, new posts can have whatever tags the author wants. That said, the reason our tags are so messy is because of that, so maybe we restrict tagging to admins/mods in edits.
