  • Replies 45
Hi Noel,
Josh said he thought you might have handbrake setup for a 33 last time I was talking to him.
Do you still have one sitting around?
All I'm after is cables, drums, backing plates etc as I already have z33 calipers.
If you don't want to seperate let me know price for whole lot.
Cheers
Jamie
Hi Noel,
Cheers
Jamie
Hey mate, If Noel doesnt have any of this stuff I do so just send me a pm after he gets back to you.
Series 1 gtst complete car with some panel damage.
machenically spot on.
ARC return flow intercooler
splitfire coil pack
Full 3 inch 5 zigen exhaust turbo back.
heavy duty clutch
hks injectors
link ecu
Pivot shift light with controller
pivot boost guage
Greddy EBC
Full mongoose alarm
turbo timer
400r skirts
gtr rear wing
17x8 skid rims with rubber
ice
plus all the standard 33 components
Will be stripping and posting parts and prices over the weekend.
Give us a call if theres anything you need on 0413863207.
have still got the gtr wing? pics please
  • 1 month later...
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
    • Do you have any before and after photos? That's $200 just for the hydro blasting?
    • Yea pedal box and no abs
    • It doesn't look like there's a lot of options out there these days, and what's out there is performance oriented aftermarket stuff (with the GTR markup) I wonder if there are other cars with similar springs, after all its just a matter of length, diameter and stiffness. Alternatively, I did see coil spacers. Probably not the best option, but could be serviceable too.
