predator Posted January 2, 2004 Share Posted January 2, 2004 How can I tell whether my water pump on the way out? Just noticed the other day i did about 200km in relatively hot conditions (about 30 up here atm). When I went to check the water, there was a significant amount that had disappeared, and it required about 3L refill. The temperature guage during driving hadn't crept up though. Apparently that is one sign that the water pump is on its way out. How quick can it happen? Will it gradually get worse and worse, or one day will it just stop pumping water completely and then big badness unless u let it cool down. My car has done about 93,000km, and its about time for the 100,000km service I guess. Was planning on getting it done in the next month or so, and still would like to stretch that a bit closer to 95,000km if i at all can. Also: oo'm not sure whether this is just co-incidence or not, but also in the last week i have noticed coolant leaking into the cabin - although I think that may be a heater hose going. I think the amount of water leaking in there can't just be attributed to the amount missing from my radiator though. Link to comment https://www.sau.com.au/forums/topic/30978-water-pump-going/ Share on other sites More sharing options...
wrxhoon Posted January 2, 2004 Share Posted January 2, 2004 thats ur problem , not the water pump .fix that first and if u r still loosing coolant check to see if the water pump is leaking Link to comment https://www.sau.com.au/forums/topic/30978-water-pump-going/#findComment-625338 Share on other sites More sharing options...
Genesis® Posted January 2, 2004 Share Posted January 2, 2004 When I went to check the water, there was a significant amount that had disappeared, and it required about 3L refill. from the radiator itself or from the reservior? Link to comment https://www.sau.com.au/forums/topic/30978-water-pump-going/#findComment-625429 Share on other sites More sharing options...
Jetdat Posted January 2, 2004 Share Posted January 2, 2004 sounds like your heater core, but if you wanna check your pump, simply wiggle your fan with the belt off looking for play...if you have any play your pump bearing is cactus. Link to comment https://www.sau.com.au/forums/topic/30978-water-pump-going/#findComment-625614 Share on other sites More sharing options...
predator Posted January 2, 2004 Author Share Posted January 2, 2004 My reservior was pretty much full before, and it had drained that and was starting on the radiator water. But like i was saying, I don't think the amount was leaking into the cabin was that much - just a few drops, but noticeable (stinks too!) Thanks jetdat, i will try doing that tomorrow. I'll also check more thoroughly the heater hoses, etc to find the source. *EDIT: its not water pump, but problem with the heater and climate control system. See other thread Link to comment https://www.sau.com.au/forums/topic/30978-water-pump-going/#findComment-625622 Share on other sites More sharing options...
pushead Posted January 3, 2004 Share Posted January 3, 2004 gordo, from the description of your problem, i had exactly the samething. Km wise is close to yours. Coolant were leaking everywhere. was dropping down quite quick. Checked all hoses and seem all ok. water pump seem to be on the way out as i can see some coolant leaking from it. did a compression test from the radiator and it appears loosing pressure. hmmmm, screw the radiator cap on really tight and since then it seems all fine. weird i know but it could be something really simple like the radiator cap not screwing on tight enough. after a few months down the track, coolant didn't drop at all, water pump seem to be ok miracle i'll say.. Link to comment https://www.sau.com.au/forums/topic/30978-water-pump-going/#findComment-627319 Share on other sites More sharing options...
