NEW ZEALAND
NEW ZEALAND
NEW ZEALAND
NEW ZEALAND
http://www.trademe.co.nz/Browse/Listing.aspx?id=272628449
Nissan skyline r33 gts25t
220 rwkw
New WOF as of 18th/feb/10
Iv owned this car from 90000kms have had it for 5 years has not let me down all the below mods where done while iv owned the car. as i owned from factory spec.
it is my daily driver and a very reluctant sale but sometimes life throws some changers your way so time for my car to go.
~AA check welcome.
~Test dives for them with proof of funds.. (am happy to take people driving)
~May swap plus min of $10,000 pending car offer
cam belt, water pump, idler and tensioners where replaced at 94,xxxkms
fuel pump replaced with a walbro 500hp pump at 98,xxxkms
new exedy heavy duty clutch replaced at 120xxxkms
regularly surfaced
NEW TOYO T1R tires $245each
mods:
performance
*HKS exhaust from turbo and hks hiper muffler
*HKS super flow pod filter + cold air box
*HKS evc 5 boost controller
*Splitfire coils
*Apexi safc-ii + tune
*Greddy type R blow off valve
*Autobarn88 600x300x76 intercooler
*Sard fuel pressure reg
*Walbro 500hp fuel pump
*NGK iridum spark plugs
*Blitz turbo timer
*Toyo T1R tyres
suspension
Nismo g-attack suspension damper adjustable front and rear strut braces
interior
white il dash gauges
alarm and immobilizer
nismo gear knob
body
led tail light
nismo clear side markers
full bodykit
gt-r rear spoiler
factory 16" r34 mags
sounds
jvc head unit
front: rockford fosgate 6.5" component speakers
rear: rockford fosgate 6.5" coax speakers
http://www.aaronradford-photo.webs.com/
http://www.facebook.com/#!/pages/Aaron...31529543?ref=ts
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
