NEW ZEALAND
NEW ZEALAND
NEW ZEALAND
NEW ZEALAND
http://www.trademe.co.nz/Browse/Listing.aspx?id=272628449
Nissan skyline r33 gts25t
220 rwkw
New WOF as of 18th/feb/10
Iv owned this car from 90000kms have had it for 5 years has not let me down all the below mods where done while iv owned the car. as i owned from factory spec.
it is my daily driver and a very reluctant sale but sometimes life throws some changers your way so time for my car to go.
~AA check welcome.
~Test dives for them with proof of funds.. (am happy to take people driving)
~May swap plus min of $10,000 pending car offer
cam belt, water pump, idler and tensioners where replaced at 94,xxxkms
fuel pump replaced with a walbro 500hp pump at 98,xxxkms
new exedy heavy duty clutch replaced at 120xxxkms
regularly surfaced
NEW TOYO T1R tires $245each
mods:
performance
*HKS exhaust from turbo and hks hiper muffler
*HKS super flow pod filter + cold air box
*HKS evc 5 boost controller
*Splitfire coils
*Apexi safc-ii + tune
*Greddy type R blow off valve
*Autobarn88 600x300x76 intercooler
*Sard fuel pressure reg
*Walbro 500hp fuel pump
*NGK iridum spark plugs
*Blitz turbo timer
*Toyo T1R tyres
suspension
Nismo g-attack suspension damper adjustable front and rear strut braces
interior
white il dash gauges
alarm and immobilizer
nismo gear knob
body
led tail light
nismo clear side markers
full bodykit
gt-r rear spoiler
factory 16" r34 mags
sounds
jvc head unit
front: rockford fosgate 6.5" component speakers
rear: rockford fosgate 6.5" coax speakers
http://www.aaronradford-photo.webs.com/
http://www.facebook.com/#!/pages/Aaron...31529543?ref=ts
    • Google says for a 1998 Nissan Maxima to pull/pry, and the metal pin might even come out with it. I'd do a bit more googling, there was a few videos, find some where the shafts/needles appear most similar and compare the techniques.
    • Details: Turbo Borg Warner EFR 9180 with 1.05 rear housing Upgraded TurboSmart integrated BOV Sanded and powdercoated compressor cover in gloss black Elbow welded with wiggins clamp Speed Sensor(Not included) (Can include oil drain(heat wrapped + titanium intake pipe with almost new filter for a tad extra). Manifold: 6 Boost RB26/30 twin scroll manifold  e-MAP ports drilled into both scrolls(I was using the TAARKS EMAP KIT) Turbo is in excellent condition. Always used Penrite 15w50 Racing oil(Changed less then 2000ks). Also using the Turbosmart OP regulator and filter. Downpipe: 4inch Stainless steel with VBand inlet and outlet clamps(included) Heat wrapped Dual ports for Dyno/Wideband usage Will throw in free 2.5 inch intercooler pipe(2.5inch From turbo outlet to 3.5 inch intercooler) - Powder coated black. Turbo made 563rwkw on mainline hub dyno at around 24-25psi boost - Pump fuel. Will def make over 600kw on e85. Didn't bother as my e-MAP was through the roof with my setup sitting past the choke line. I have a cnc ported and fully built head on my 3.2. Turbine speed saw max of around 109k rpm. I'm running this on my R32 GTR, with AC, and the original power steering pump. The manifold clears the AC lines, ABS, and everything else. Although I had new AC lines because I just wanted new ones and I heat wrapped them as well. This will make more power on a slightly lower capacity motor with a higher PR. And I have since upgraded to a G45-1500. Have pics and videos if need be.  Absolutely nothing wrong with setup. Turbo is in perfect condition. No shaft play or oil leaks at all. All the work was professionally done. The transient response of this is fkn amazing. I cannot rave more about this turbo. If I wasn't chasing 4 figures, I would have kept it. $5000 NZ. Located: Auckland, New Zealand.
    • I particularly like the look of the John Player Special team. (Thumbnail isn't different but hit play for the clip)
    • Such a cool collection of cars back then.
    • Mystery solved, thanks bro Bit of a strange mix, but i dont mind it, still looks good.
