Recently i bought myself a 2nd hand exhaust which included a 3" mild steel front pipe highflow cat and 3.5" stainless steel catback exhaust.
I haven't installed the system yet as i am still tossing up between getting a new dump and front pipe or just running the stock dump with exhaust as is. The mild steel front pipe is made to bolt straight up to the standard dump as it tapers down to 2.5" at the dump side. Due to this fact i would be looking at replacing both front and dump pipe if changing them is recommended.
Now i am only really going to be street driving this car and not going overboard with mods. Plans are the exhaust, possibly FMIC although may not be getting up to those power levels where it is needed and a Nistune. Plan to keep the standard turbo and run around 11psi.
At this basic level of modification would the factory dump be a restriction at all? And even if the dump isn't a restriction is there going to be much of an issue going 2.5">3">3.5"?
https://www.sau.com.au/forums/topic/309802-r34-exhaust-suggestions/
Anyone able to give us a hand? I'm sure theres a few people who have a good idea on whether the standard dump is very restrictive or not and whether the changes in size of the exhaust throughout will affect flow/performance.
  • 6 months later...
Going from small to big shouldn't hurt the flow. The standard dump pipe would be more restrictive than an aftermarket in some way.
The rule of thumb is the more power you pushing out from the engine, the more power increase a well suited exhaust will give you (to some extent of course).
The stock dump is still a restriction.
Just get one of them justjap front/dump pipes they're pretty cheap, coz you're not after big gains.
Ideally you would want it to be 3" or larger from the turbo back.
Have you got a better flowing panel filter or pod filter?
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
