I am going to sell my Stagea and get a GTR. I was wondering if there was any point advertising in Aussie with all the import laws etc (which I know nothing about).
My Stagea is 557kW at the wheels, with a mod list a mile long. Engine, drivetrain, suspension, interior, exterior, audio, EVERYTHING has been done.
Is there any pont in say ebay.com.au?
Cheers peoples.
https://www.sau.com.au/forums/topic/309815-selling-my-stagea-in-aussie/
Not with thise mods man - it would still have to go through compliance and that means all but taking it back to stock for registration purposes. The only way it could happen is if you sold it to an aussie over there, he owned it for 12 months and then brought it in as a personal import. I "think" it may bypass the compliance proceedure, but dont quote me on it.
Plus the arse has completely fallen out of the prices here. Just ask anyone trying to sell one thats already here.
Seeing as I am an Oz citizen, what if "I" brought it over, had it complied then "f me..!!" sold it...??
You might have trouble getting back in the country with that username MR Pure Methamphetamachine
If you are an OZ cit then you would be able to bring it in as a personal import, that actually means no compliance requirements (or very little) need to be met. If you looked into it seriously and it was doable then you could advertise it over here, based on that scenario for sure.
A few of the importers sell "personal imports" that their staff living in Japan (Australians) have owned for 12 months, the vehicle is then imported under the personal import scheme.
Some details here: http://www.worldshipping.co.nz/forms/aus/o...eligibility.pdf
Edited by munchstagea
Car Itself
RB28DETT
Each engine component balanced to 1 / 1,000,000kg
N1 Block
Tomei Modified Tomei Forged Pistons
Tomei Forged Conrods (2.8 litre)
Tomei Forged Crank (2.8 litre)
ARP Conrod Bolts
Custom Ported and Polished Head
Custom Valve and Valve Seat Design
Tomei Cam Shafts
Tomei Slide Cam Pulleys
Tomei Valve Springs
Tomei Valve Spring Retainers
Tomei Valve Buckets
Tomei Valve Guides
Nismo Plenum
N1 Oil Pump
Nismo Oil Baffles
HKS T51R KaiBB Turbo
HKS Extractor Manifold
HKS Front Pipe
HKS Drag 60mm External Wastegate
HKS 100mm Dump Pipe
A’PEXi 100mm Exhaust
HKS Air Filter
HKS Map Sensor
HKS Intake Piping Kit
HKS Compressor Outlet Piping
GReddy Induction Hard Piping Kit
Twin ARC Blow Off Valves
Nismo Engine Mounts
Nismo Gearbox Mount
Nismo Metal Head Gasket
Tomei Metal Throttle Gaskets
Tomei Metal Intake Gaskets
Tomei Oil Restriction
Nismo Main Bearings
Nismo Big End Bearings
Nismo Centre Bearings
Complete Nismo Seal Set
Gates Racing Belts
Blitz Racing Plugs
HKS Metal Exhaust Gaskets
Procoated Piston Crowns
Procoated Piston Walls (Teflon)
Procoated Manifolds
Procoated Dump Pipe
Custom Blow Off Valve Control System
Custom Oil Catch Can
Custom Ignition
Fuel System:
Bosch 044 Fuel Pumps (x2)
11 litre surge tank
Tomei Fuel Pumps (x2)
Sard 1000cc Injectors
Sard Fuel Pressure Regulator
Tomei Fuel Rail
Custom Dual Fuel Cooler System
Cooling:
GReddy 600mm x 300mm x 115mm Core FMIC
GReddy Hard Piping Kit
GReddy Oil Cooler
GReddy Oil Filter Relocation Kit
GReddy Radiator Piping
Custom Evaporator Tank
Koyo Twin Core Alloy Racing Radiator
Power Steering Cooling System
Suspension:
BC Adjustable Suspension
Kazama Adjustable Upper Rear Arms
Kazama Adjustable Lower Rear Arms
Kazama Adjustable Rear Tension Rods
Kazama Adjustable Pillow Mount Rods
Drivetrain:
Series 3 R33 GTR Gearbox
Nismo Super Coppermix Twin Plate Clutch
Nismo Chromium Molybdium Fly Wheel
Nismo Pressure Plate
Nismo Release Bearing
Nismo Slave Cylinder
Tomei LSD
Brakes:
Brembo Calipers
Brembo Rotors
Endless Pads
Electronics:
HKS F-Con V Pro ECU
HKS EVC V Boost Controller
GRID TS Dancer
HKS Turbo Timer
Defi BF Boost Gauge
Defi BF Fuel Pressure Gauge
Defi BF Oil Pressure Gauge
Defi BF Exhaust Temp Gauge
Defi BF Oil Temp Gauge
Defi BF Water Temp Gauge
Defi Link II Controller
RevLite Sequential Shift Light
Exterior:
Custom Front Bumper with additional air rams for oil cooling, air intake etc
260RS Side Skirts
260RS Rear Bumper
Ganador mirrors
Nismo Smoke Indicator Lenses
Nismo Xenon HID 4,300k Low Beam
Mantis 55W 15,000k HID High Beam
Front Guard Flaring
Rear Guard Flaring
Full Respray
Dolphin Grille
Interior:
Dolphin 300km/h Speedo
Dolphin Meter Hood
Series 3 R33 GTR Seats
Nismo Gear Knob
Momo Wheel
Nismo Floor Mats
Rolling:
Rays / Volk GTC 18” x 10” 2 piece forged +17 Wheels
275 x 35 R18 Toyo Trampio all round
Rays Valve Caps
ICE:
Pioneer AVH-P7950DVD Touch Screen DVD
Pioneer DEX-P01ii Head Unit
Pioneer DEQ-P01ii Equaliser
Pioneer CD-IB100
Pioneer CD-RB20
Kicker ZX850.4 Amp
Kicker ZX750.1 Amp (x2)
Kicker ZX200.2 Amp
Kicker Remote Bass Control
Kicker Hyper Flex Power Wire
Kicker S8L7 Subs (x4)
Hybrid Audio Legatia 6.5” (x4)
Hybrid Audio Legatia 3” (x4)
Hybrid Audio Legatia 1” (x2)
Custom A Pillars
Custom Door Pods
Custom Door Panels
Custom Sub Enclosures in Boot
Extra Batteries
Kicker Distribution Blocks
Kicker Battery Terminals
Kicker S Series RCA's
Kicker Fuse Blocks
Additional:
Custom Radiator Breather Tank
Custom Overflow Tank
Custom PS Cooling System
Custom Fuel Filter Brackets
Custom Fuel Rail Brackets
Custom Fuel Reg Brackets
All Oil Lines Braided
All Fuel Lines Braided
All Water Lines Braided
All Vacuum Lines Braided
All Manifold Lines Braided
All Wastegate Lines Braided
And more, but I forget...
The detuned run:
NZ$85k, so about AUD$67,000
God damn slow internet.. Will look at that link when I can. Cheers dude
Edited by pure_methamphetamachine
No offense intended, but I wouldn't be selling anything in the current financial climate. Its a buyers market, which basically means everyone's broke LOL
There's a guy at carlsales.com selling a 260RS for $37,500. That car has been advertised (from memory when I noticed it) for at least 6 months, probably longer, and it started off, from memory at $45,000 (don't quote me on that though)
Granted he may not have done half the stuff you have, but finding a buyer in this climate, who knows ...
Good luck, I hope you not only find someone, but you get a fair price for it too. Me? I'd be holding onto it. That is of coarse unless I win lotto, then I'd just by whatever I want and extend the garage :cheers:
the other option is race only use (other than personal import). but the regular import rules require a standard car, and in theory the modified parts have to be destroyed after being removed.
you can thank toyota for the current import rules - they didn't want to compete with their own landcruisers cheaper from jp
Buy a schmick bodied (no rust) GTR & transfer all your gear, or, wrap it in plastic & wait for the financial climate to turn around, else, "suck it and see".
Maybe ask "Guilt-toy" what side of the road they drive on in the USSR?
My 2c
Best of luck whatever path you eventually choose.
GW
this car is the most heavily modified stagea probably in the world, just advertise it, some loaded car freak might just see it and would pay anything to have it, if i won the big one tonight i'd be buying it no matter what it took to get it here(ps i'd also be picking up a r34 gtr etc etc as well) :P
Driveshaft is fine. It's just the factory one. They can take a serious beating. I know of a 580kW track car that gives it death, and it has never died (r32 so less weight though).
Maybe I will just advertise and see. Even if someone buys it just to strip and place everything in their own car..??
