For Sale: I have 4 Genuine Stern 1 piece wheels from japan with Continental 245/40/17 on them
Located: in Melbourne
Price: $600 ONO
Came off my R32 GTR.
Offset: Unsure, but they sit flush with guards on GTR. No rubbing.
Size: 8 inches wide by 17 Inches
Condition: Gutter rash on front left, pic attached. Tyres are done.
Reason For Sale: Upgraded to 18 Inch P1's.
Inspections Welcome
PM Me or call 0410 561 741
Cheers.
https://www.sau.com.au/forums/topic/309820-genuine-stern-japanese-wheels/
Price: $600 ONO
Inspections Welcome
Cheers.
do you know if they fit on evo's by any chance? evo 7 to be precise
Hey mate,
On the wheels there is nothing listed in regards to offset apart from this: "OFF 1/8" which I don't understand
All I can tell you is they sit flush on an r32 GTR.
Apologies for the minimal knowledge and information
Paid this guy for these wheels over a week he made up some rubbish about the courier, He said he would give me the cash back and has not and now won't return messages or calls.
Admins can you please help?
  • 4 weeks later...
Issue finally resolved with Paul AKA GRYGTR on Friday the 23rd of April.
http://www.skylinesaustralia.com/forums/Ta...sh-t317260.html
All Pm's Replied
Will probably be a little too wide for an evo, I suggest doing some research.
actually would look really tuff and make for an aggressive looking evo, question is will they clear the brakes...
Plenty of evos sporting upto 18x10 +20 offset at all fours just have to choose the right size tyre and dial in the camber
Thanks Sav,
I had no idea if they would fit an EVO. Just was thinking on the safe side of things just in case as i dont believe they will clear the big brakes.
Camber is another matter all together though as you can fit most wheels on if you can play with wheel angles.
Cheers
Josh
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
