Hi guys,
These are the remaining 1999 R34 GT-T 4-Door parts i have left over. Main items like engine,gearbox,wheels, headlights, rear lights, all panels, seats front and rear are sold.
But if you have something your interested in and i haven't listed it please pm me and ill get back to you asap.
I will update parts each day. Hard to add all in one day so keep a eye out on this thread.
R34 GT-T Bonnet $250
Automatic GT-T Transmission approx 80,000k excellent condition $450
Rear Windows $100each
Smaller Rear Windows $80each
Front Windows $120 each
Door Rubbers $20each
Center Console $30
Door Handles minus locks $40each, can work something out for the set
Glove Box Complete $75
Complete Auto Tail-shaft $150
Tranny Cooler $80
Front Doors left & Right minor damage. Only Door shell $50each
Parts are located in Thomastown, Northern Surburbs of Melbourne. Can send some items via post if required.
Cheers.
Terry.
  • Replies 56
Posted Images
hay buddy
i need the ash tray and climate control panel if u can help a brother out
cheers
julz
Sorry champ, both ashtrays & climate control unit sold.
Prices are slightly neg.
Cheers
pm sent
pm replied
hey mate, have you got the stock air box filter?
sold
Hey just putting this out there.. do you have a double DIN headunit surround?
sold
Still heaps of stuff left guys.
Front rotors?
sold
Cigarette lighter or steering wheel available?
sold
Power windows mechanism;
Front Drivers Side $120
Passenger Side $100
Rear Left $ 80
Rear Right $80
R34 GT-T Manual Radiator $150
Complete Standard R34 GT-T Exhuast from turbo back $300
R34 Sedan Seat belts. Let me know what your after and ill give you a price.
R34 GT-T Dash, perfect as it has the original cutout for the triple guage cluster $200
All prices neg.
Cheers. Terry.
can i get price for
side panel next to the headunit as per pic (if it has not marks on it)
and im guessing the guards are sold?
Both Sold
what colour is the bonnet..
Was Blue, sold yesterday.
Throw me some offers guys. Cheers.
Mate do you still have the Right Hand Side Mirror?
SOLD
wierd ask i know but do you have the r34 mud gaurds? there a plastic add on to the stnd kit.
Never on the car.
4 pieces of the door window visor?
SOLD
    • When sanding across a convex panel, you need to sand, as much as possible, at right angles to the curve. If the panel is compound convex curved (ie curved in both directions) then you are SOL and have to use "craftsmanship" to get it right.
    • Today in Skyline arts and crafts!! I鈥檝e made some progress.    had to put extra notes in there so I don鈥檛 stuff it up 馃槀
    • This sounds like me. And then why I leave shit that I had previously hobbled together broken. Lately I've changed strategies to "If I don't want to justify the money on decent stuff, I'm not going to justify hobbling it together". I'm still for DIY, but DIY it properly is more my thing. However, I am terrible on not setting up backups still... Which reminds me, I need to go backup some of my work VM machines... Oh, it's also why I've become a lover of building things into Docker Containers... Then I just need a machine that can run docker, and bam, that specific system is up and running, on the specific versions of everything I need for it to run (In the event a change in required software version breaks something else). Also, these days, my steep learning curves are spent with work related stuff, and on very varied projects, that my want to do other random projects like build a dashboard for my own car has dwindled away to "I just want the car running", which is my current PITA, as I'm getting the Landcruiser usable again, and it has just been non-stop the past 6 to 8 weeks of buying parts, and working on it. Oh, and tools that are meant to be fit for purpose... And they break, because 25 year old 4WD decides it's stronger... But by the time I have it ready to roll back out the drive way, nearly all the stuff in it will have been touched and serviced, so the damn thing better give me NO FREAKING ISSUES, for at least the next 50,000KMs! Just redone whole front of the motor, and resealed the up top stuff, replaced a bunch of things getting perished, new timing belt done, water pump, lower timing cover (Toyota diesel engine runs timing GEARS for the bottom half the motor, and a timing belt from halfway up to the top), new harmonic balancer, fix up the alternator, new thermostat, full swivel hub rebuild, new bearings and seals front and back, steering box rebuild, new battery, and today, it turns out a rear shock has let go, so four new shocks are about to go on order, and that will leave me with after the next run of work, to see if I need to order just a brake caliper re-seal, or if I'll need new pistons in them too. Oh, and I'll finish welding in the new floor sheet metal shortly too. Presently I just want it finished already... But once all the above is done, I still need to fully service diffs, gearbox, transfer, and motor. Then flush and bleed the clutch, and flush and bleed the brakes. But enough about our waffle, back to Duncan's heat problems... I think for Duncan he just gets a thermoswitch, and a manual switch to run some water misters. Thermo so it's only on above certain temps, and the manual switch so it can be turned off even if it is above certain temperatures. IE, switch on for "I'm now on track", then it doesn't need any "smart" computers that might try and do things wrong. And switch the thing off completely on the cool down lap, so when he stops in pits, there's not even a possibility of it dripping any water out to get him in trouble.
    • So I ran into the same problem. I got stuck in the cycle of again of putting putty sanding it, putting putty sanding it, because of a low spot. And notice my block is not completely flat with the panel, even though it's a long block. My panel is slightly curved. Is this an issue? Do I need something that matches the door perfectly, or no?    I do have the smaller flexible block that covers the width of the repair just not the length, I was experimenting with it again to but seems to be the same issue
