well hopefully i can escape the tax - the box is getting turned inside out and getting labeld "gift" :(
i'll take the risk
I would delete this post if I was you.
Other people read these forums that may be interested in that....
Cheers
Ken
  • Replies 64
deleted- now u delte urs since u quoted  me :P
and ken that price i said inlcluded shipping - it was just minus tax etc
cheers
BRAD
The plenum is sitting at WA customs as we speak while they sort out value of/tax/GST so don't think you are not going to get stopped.
As I said anything from Japan performance related is being scrutinised.
Cheers
Ken
LOL!! - ok i've decided to not go with the purchase of the plenum as $1500 could be put to better use else where. Now all i'm searching for is 300-350 wrhp out of a RB25DET which is fitted into a S13 silvia - (to much hp will be crazy) - mods already fitted will be a Wolf 3D, 3" stainless zaust, pod (typical - lol), FMIC, and Bosch 044 pump ;)
what would the next best mod using about $1500 to get me to my goal of 300 - 350 wrhp?
cheers
BRAD
the combo youve described above should get you close to 300 in a skyline. assuming the drivetrain losses are the same you should be nearly there.
you'll be struggling to get more than that out of the standard turbo though.
s/hand t3/4??
either way, I would like a ride in a 350 rwhp silvia.
the notion that nissan spent years pondering the best way to extract small HP improvements and maximum flow from their plenums is just ridiculous. The factory plenum is designed to be as cheap as possible to manufacture, whilst still performing the job adequately for purpose - i.e. low boost road use applications.
Why is a forward facing plenum included on everything *except* the gts-t then? Even Nissans 'budget' CA18DET and SR20DET motors include one. So its basically not cost. I'd say its just efficiency and suit for purpose as stock, and as people are saying - you're not probably going to notice the gains on a fairly stock setup. Start shoving more boost in, flowing more air into the inlets, and then it might become an issue if the chambers are restrictive.
From what i've seen/read it really becomes a gainer *after* you've stepped up to bigger turbo land. But every little bit helps along the way.
when i was at speedworks i saw a lancer that had just had the intake manifold changed. from something standard to a jun one. runing only 1.2 bar boost it make 80 ps more than when it was running 1.7 bar. even aj at speedworks couldn't beleive the results. i think it simply proves how much extra power can be tuned from a car with high quality parts.
having a better plenium will make a difference, less restriction at higher flow lets the cylinder pressures go higher at lower boost. how ever if you dont have a bigger turbo, fmic and management i wouldnt c you could actually utilize this item. if you do have these items
im yet to look at the internals of the greddy plenum, i would like to do this before i decide weather its worth making my own from scratch or purchasing one of these. if i can design and build this from scratch with no real problems i might consider making more. how ever i need to put more reserch into this before i start. anyone whom could help with any info i might need i would love to hear from you.
Matty B
  • 2 months later...
    • If you do go with drain back, make sure everything is foam or wool filled so it actually does something, and ensure there is a screen somewhere in the drain to catch anything that comes loose from the packing. I don't drain back
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
