The real question is, did they do the tunnel thing for real? I highly doubt they did, but it would be awesome if it was. I might do some google'ing and see if it was real.
Good. Update us if you find anything... looks right but can be CG too. You never know whats real or not real. What have the world become?!?!?!?!?
E.G.
http://www.youtube.com/watch?v=bRVlnH09FFE
https://www.sau.com.au/forums/topic/309869-sls-amg/#findComment-5108659
Did a bit of research. Most people say it is fake, and it most likely is but no one has really released anything saying it wasn't real. Having said all that im sure Mercedes have enough money and engineering skill to pull something like that off. Physics proves it is possible and hell even Top Gear gave it a go in a "not so aerodynamic" car.
https://www.sau.com.au/forums/topic/309869-sls-amg/#findComment-5108745
god that add is full of shit . why is he on the limiter when he pulls it in to the cap park after gettin it off the truck? why does he need two twats waving their hands so he can drive it out of the truck ? what are the stupis 25 50 75 100 125 signs for ? why the f are the numbers on our side . why do they cut to a scene of the guy dong maths on a bit of perspex right before they do the stunt . havent they worked it out yet ? it you went to all that effort to do that wouldnt you film it in a way that made it look real ? eg one camera continous?
https://www.sau.com.au/forums/topic/309869-sls-amg/#findComment-5109051
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
