Need to help fund my recent contribution to the GTR money pit and make some room in the garage!
All items in Melbourne, happy to post at buyers expense for the lighter items, prefer pickup for the heavier items, or might be able to meet people somewhere closer in.
Apex AVCR silver model
Full kit includes dash unit, solenoid, map sensor, wiring looms and stand (never used) if you want to mount on your dash
Wires in to your ECU to for RPM, injector duty, boost, vehicle speed and solenoid duty
Has some light scratches on the control unit
I have PDF's of all the installation guides in english so will include on a CD
$360
Standard R32 GTR ECU (9/89)
Excellent nic - working when Racepace pulled it off or PFC, only thing EPA broke one of the screws when RP were using it to clear defects on another car
$100
2 x Standard R32 GTR turbos (9/89) - see pics
Working perfectly when Racepace pulled them off to put on the GT-SS's
Perfect cheap option if you blew yours, or want frames to have rebuilt with steel wheels / highflowed
Include actuators
$150 each
1 x Standard R33 GTR turbo - see pics shiny clean one
Working perfectly when pulled off R33
Includes actuator
I have another of these I just can't find it...
$200
Standard R32 GTR dumps with heat sheilds - see pics
Good nic, not much can go wrong with these
$100 pair
Standard R32 GTR boost solenoid
$50
Standard R32 GTR cam gears
Good nic, once again working perfectly when RP pulled them off for adjustables
$100 pair
Garret exhaust housing - not sure what its off but has a standard T25 flange without the weird entry, and is the GTR size exhaust wheel, .49AR, just needs to be re-profiled
and you could adapt standard GTR turbos to smaller capacity engines around 1.5 litres - perfect for an ET pulsar if any still exist!!
$50
Standard R32 GTR steering wheel
Good nic
$100
Standard R32 GTR front (4 piston) and rear (2 piston) sumitomo calipers
including cross drilled, vented rotors, standard lines and used bendix ultimates, working well before pulled off for upgrade
$500
Standard R32 GTR suspension
$100
I'm looking for an R32 GTR ashtray if anyone has one.
Also have R32 GTR wheels for sale in another thread.
https://www.sau.com.au/forums/topic/309902-r32-gtr-and-r33-gtr-parts-clearout/
bump - still for sale
- Standard R32 GTR ECU (9/89)
- 2 x Standard R32 GTR turbos (9/89) - see pics
- 1 x Standard R33 GTR turbo - see pics shiny clean one
- Standard R32 GTR dumps with heat sheilds - see pics
- Standard R32 GTR cam gears
- Garret exhaust housing
- Standard R32 GTR brakes - front (4 piston) and rear (2 piston) sumitomo calipers with discs/pads
hey mate ill give u 150 for the r33 turbo?cheers
I noticed you have a 32 GTS-t? - what car are you wanting to put it on, as it's a GTR turbo (i.e. 1 of 2 on an Rb26) will be too small for an Rb20, not to mention it won't bolt on
- Standard R32 GTR ECU (9/89) - $100
- 2 x Standard R32 GTR turbos (9/89) - see pics - $150 each
- 1 x Standard R33 GTR turbo - see pics shiny clean one - $200
- Standard R32 GTR dumps with heat sheilds - see pics - $100 pair
- Garret exhaust housing suit adapting gtr turbos to normal T25 flange - $50
- Standard R32 GTR brakes - front (4 piston) and rear (2 piston) sumitomo calipers with lines/discs/pads $450
