Roughly. I think Eric (person who worked on Gibson R32 GTR racecars and now builds Targa, road spec GTR's, etc) worked it out to be 35% loss when engine dyno was compared to roller dyno (was mentioned in a magazine, so don't know how accurate the info is) for R32GTR, R33GTR. Not sure what torque split was used, as I've noticed torque split affects the final kw output at wheels. More rearward bias = higher kw at wheels.
210kw x 1.35 = 283.5kw x 1.341 = 380hp at engine.
Edited by SKYPER
https://www.sau.com.au/forums/topic/309903-atf-vs-atw/#findComment-5107909
35 % loss is a fair chunk of power thats suprising , i think every car should be rated at the wheels , great info cheers
https://www.sau.com.au/forums/topic/309903-atf-vs-atw/#findComment-5108112
35% loss hummmmmmm
Looky here
Thats 299bhp ATF
convert that to kw its 220kw just give or take
as a rule of thumb ive always calculated transmission lose at 15% as its not a continual torque engine
At the wheels mine would be around 255bhp or 188kw
Ok same car same rollers same guy stock manifold pressure no mods
255bhp 188kw ATF this time not wheels remember
Thats 217bhp ATW roughly 160kw ATW
Edited by jjskyline79
https://www.sau.com.au/forums/topic/309903-atf-vs-atw/#findComment-5108451
The only way to do it is to dyno a large cross section of vehicles both at the wheels and on the engine brake. Then generate a generic table with error bounds attached.
If you take into acount, gearboxes, diff set ups, tyres, heat at the tyres, tyre pressure, power range, revs to achieve it, your doing better than me.
A car that revs to 12000rpm will create more friction, a 1000hp car will create more friction, your tyres with 50psi in them generally gives more power [one for the dyno queens to remember], different brands/types of tyres will dyno optimally at different times and heat ranges, a lock diff will absorb more energy early but may actually be better at higher revs because you are using both rear tyres equally and so it all goes around and around.
The only true way is to do both dyno runs with the same motor, even then you may not have the best tyre on for the job.
So any any equation or ROT applied is an approximation - end of story. But a ROT is OK to use as long as you accept the bounds it creates with a high and low pass.
https://www.sau.com.au/forums/topic/309903-atf-vs-atw/#findComment-5108559
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
