justing getting rid of a few parts i wont need anymore
1) Brown Davies Roll cage to suit a R34 2 door, powered coated white, completely welded together as one piece, to fit to the car have to remove both seats and the centre console and slips right in lol, this cage is cams approved and vic roads
$1000
2) HKS 2835 Pro S, i made 292kw at 1.2 bar turbo has done well under 5000kms comes with water and oil lines, snail type hks dump pump, its a T3 flange still fitted to the car
$2200 neg
3) Nismo 480cc injectors to suit a RB25 NEO, 4 hole spray pattern once again i made 292kw with the hks turbo, comes with the o-rings and injectors,done under 5000km
$650
4) ARC reverse flow intercooler, used this intercooler on my car for approx 12 months, looks factory under the bonnet no leaks or not what never had a issue with it, suits a R34 RB25DET comes with all piping, silicone joiners and clamps
$ 600
5) Power FC to suit a R34 NEO comes with the hand controller, never had anu issues with it still fitted to the car tuned with 480cc injectors, 2835, Z32 etc etc
$1200
PICS WILL BE UP LATER TODAY!!!!!!!!
PLEASE RING ME ON 0401035221
you can PM me but just ring me instead
all parts located in the south east of melbourne
thanks tom 0401035221
  • 1 month later...
$1000
$2200 neg
$650
$ 600
$1200
Hi, I am Alex from Mordialloc. Is it a half cage? 0433878905
cheers
HKS 2835 PRO S turbo kit, dump pipe oil and water lines etc
$2200
genuine East bear R34 GTR front bar to fit a GT-T or GT requires gtr bonnet which also is for sale
$500 NEG ONO!
$150
3" cat back exhaust came off a r33 has been made to be tucked up close as possible to the body for ground clearance
custom intercooler pipes with a Z32 moulded into the pipe work, gives the factory look had it on my car with the 28/35 pro and arc intercooler
$250
BMC panel filter suits all RB25 RB20 DE and DET air boxes good condition lucky to have 1 hours dyno time on it, held power back using a air box so went with a pod filter
$50
ARC intercooler all piping needed etc
$600
R34 GTR MFD, all wiring looms needed and plugs, comes with top cover also
$1000
EDIT genuine East bear R34 GTR front bar to fit a GT-T or GT requires gtr bonnet which also is for sale
$500 NEG ONO!
EDIT
number plates and cat not included!
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
