justing getting rid of a few parts i wont need anymore
1) Brown Davies Roll cage to suit a R34 2 door, powered coated white, completely welded together as one piece, to fit to the car have to remove both seats and the centre console and slips right in lol, this cage is cams approved and vic roads
$1000
2) HKS 2835 Pro S, i made 292kw at 1.2 bar turbo has done well under 5000kms comes with water and oil lines, snail type hks dump pump, its a T3 flange still fitted to the car
$2200 neg
3) Nismo 480cc injectors to suit a RB25 NEO, 4 hole spray pattern once again i made 292kw with the hks turbo, comes with the o-rings and injectors,done under 5000km
$650
4) ARC reverse flow intercooler, used this intercooler on my car for approx 12 months, looks factory under the bonnet no leaks or not what never had a issue with it, suits a R34 RB25DET comes with all piping, silicone joiners and clamps
$ 600
5) Power FC to suit a R34 NEO comes with the hand controller, never had anu issues with it still fitted to the car tuned with 480cc injectors, 2835, Z32 etc etc
$1200
PICS WILL BE UP LATER TODAY!!!!!!!!
PLEASE RING ME ON 0401035221
you can PM me but just ring me instead
all parts located in the south east of melbourne
thanks tom 0401035221
  • 1 month later...
$1000
$2200 neg
$650
$ 600
$1200
Hi, I am Alex from Mordialloc. Is it a half cage? 0433878905
cheers
HKS 2835 PRO S turbo kit, dump pipe oil and water lines etc
$2200
genuine East bear R34 GTR front bar to fit a GT-T or GT requires gtr bonnet which also is for sale
$500 NEG ONO!
$150
3" cat back exhaust came off a r33 has been made to be tucked up close as possible to the body for ground clearance
custom intercooler pipes with a Z32 moulded into the pipe work, gives the factory look had it on my car with the 28/35 pro and arc intercooler
$250
BMC panel filter suits all RB25 RB20 DE and DET air boxes good condition lucky to have 1 hours dyno time on it, held power back using a air box so went with a pod filter
$50
ARC intercooler all piping needed etc
$600
R34 GTR MFD, all wiring looms needed and plugs, comes with top cover also
$1000
EDIT genuine East bear R34 GTR front bar to fit a GT-T or GT requires gtr bonnet which also is for sale
$500 NEG ONO!
EDIT
number plates and cat not included!
    • Nothing wears "the most". Different cars will always show signs in a different place. 114000 km is either nothing at all (as in, given the calendar age, nearly brand new) or it's completely unbelievable. We stopped believing numbers like that about 15 years ago. Having said that, my car is up around 270000 km and I have put bushes into some places** as many as 10 times in >25 years that I've owned it. ** FUCAs, which are different on an R32 than on a 33, so not likely to be the same issue for you. I have original ball joints all the way around. They are perfectly fine. Same with the spindle bearings in the front. Tie rod ends have all been done at least once though. Pretty much every other bush in the car has been done at least twice. Some of those in the first 100000km after I got it (which was at a genuine 23000!). Some of those bushes are now sphericals, and they are on a <cough> regular maintenance schedule, hence why my FUCAs have been rebuilt so many times. Half of those 10 in the count above would be in the last few years! 'twere I you, I would budget on replacing everything, for fun and prevention. If they really are 30 year old rubber, they will all be unpleasantly aged in one way or another. Whether that's corrosion of shells, or the rubber cracking, or sagging under the load, etc etc.
    • Tighten until it starts to get loose again, then back off 1/4 turn?
    • Do them as you'll find when you remove them they are perished/dried.    Its probably one of the best things to do as makes the car so much more responsive. Do ball joints while there too.
    • Hi All Got an R33, about 114,000km on the clock.  Handles very nice, no signs of issues.    Engine is out and i'm doing an underbody refresh, mainly painting subframe, cosmetics etc. Can't see anything physically giving play, but I'm wondering which bushes are the ones that wear the most, or the first ones that may give problems down the track? For good measure I'm thinking to fit new ones. Thanks
