hey everyone, :P
selling my r32 gtst as i want an s14 :P
1992 R32 GTST
BODY
GTR gunmetal respray with lots of perl ( ful jub in boot engine bay ect)
GTR front bar
GTR side skirts
GTR rear pods
GTR N1 boot lip
GTR Rear wing
GTR rear bar
20% tint all round
GTR n1 headlights.
ENGINE
Rb20det
R34 op6 neo turbo
AM performance screamer pipe
Xr6 turbo fuel pump
boost controller
Greddy fmic
Air flow meter relocated to intercooler piping
Metal intake pipe
3" stainless turbo back exhaust
3" stainless cat converter
Xtreme HD clutch ( just pretty much a stock replacment .. works good nice and easy)
Suspension
Oteins front coilovers
JIC magic 2deg neg front camber arms
New castor rod bushes
Hicas lock bar
GTR rear swaybar
some random rear coilovers ( not too bad )
G maxx Drift 6 17x8 and 17x9's ( 15 mm bolt ons on front and 8 mm slip ons rear ) stretched 215's all round.
Interior.
Recaro bucket reclinable bucket seat
K's design din guages
water temp
oil pressure
oil temp
Autometer air fuel ratio guage
Blitz boost guage
Nismo 260 kmph speedo
enuf doof doof to keep the chicks happy ....
Now the car was originally Non turbo, a complete driveline swap was done, and all legally :(
the car still retains 4 stud, as i really like the wheels on it , it has turbo brakes re drilled, and comes with all the nesicary 5 stud hardware , if you wish to go 5 stud . but u would need new rims, and i like these ones :( nismo speedo shows 61,000 kms ... other speedo was on 100 , so around 160,000 kms .
The paint is really something nice about the car, its pretty much immaculate, couple of little pin dents but thats it
pref looking for swaps for S14.. or 11k ....
please PM me for more pictures or swaps .. located in SA..
https://www.sau.com.au/forums/topic/309937-1992-r32-gtst-minter-than-your-mum/
  • 5 weeks later...
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
