Hey guys,
I have recently finished an engine conversion from a 20de to a 25det in my r34, After driving it for about a week just coming off the dump pipe I put it into the workshop yesterday to have a full exhaust system installed, Anyways....I started the car first thing this morning and pulled out of my driveway and proceded to town, When I got home my sister informed me that the car was smoking in first gear, white smoke and she said a wee bit into second but not as bad. So I had a wee look around the car and found an oily residue inside the exhaust pipe, Im thinking turbo? after that I did a few searches here on SAU and have drawn a blank. Im guessing its the turbo but it still boosts as it should and apears to be working fine...
Any suggestions as to what I can do?
Cheers,
https://www.sau.com.au/forums/topic/309957-rb25det-exhaust-smoke/
What does the smoke smell like?
If it smells like burnt oil, I'd say turbo - this smoke is usually blue though. If it goes away under boost, I'd say its not the turbo.
If it smells sweet, it could be headgasket - this smoke is usually thick and very white.
If it smells like unburnt fuel then it could be spark plugs, coils, injectors, something fuel related.
Some cars can blow a bit of smoke on cold startup - and it could be a myriad of things.
Do a compression test, that will rule out anything major like valves or piston rings.
After that I'd go to a performance shop and get them to put it on the dyno, see what your A:FRs are...
BTW, I didn't know RB20DEs came out in an R34!? Are you sure it wasn't an RB25DE?
It was definately a 20, A mate also has a 20 in his r34, Cheers for the help will start looking them through tomorrow. really hoping its a simple fix as I have already poured thousands into the car in the past month.
Ohk didn't know that!
From Wiki:
The RB20E engine was discontinued in the R34 base model (GT), and the RB20DE, after last being used in the R32 Skyline, was reintroduced in updated NEO guise
Another thing, it could be a small vacuum leak maybe? Did you forget the carbon canister or any of the vacuum lines when you did the conversion?
(not doubting ya or anything, just going through the possibilities)
Does it still drive fine? i.e. lost any power?
Im not exactally sure, I had a mate do the entire conversion for me, will have a look in the morning, where would this canister be in the engine bay? Also it was a complete engine swap, the turbo, oil lines etc were already in place.
Edited by Raki_King
The carbon canister has rubber lines coming out of the firewall, dunno if they're on the intake or exhaust side but have a look around (and under the car) for any hoses/lines that aren't connected. The actual carbon canister is in the rear of the car I'm pretty sure, you'll just see the lines.
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
