Hi guys, I have serious trouble getting up driveways and it's been confirmed now that only one week is spinning :P
what are my options, do I get this one rebuilt, second hand R34GTT, I also heard an S15 diff is the same, what about a R34 GTR rear diff?
how much better is a 1.5 turn, and is it a worthy upgrade, i don't do any drifting or anything like that?
thanks for your help
cheers
chris
https://www.sau.com.au/forums/topic/309966-r34-gtt-diff-farked/
I wouldn't say it's, farked, torsen diffs (in S15/R34 GT-t) do that when there's one wheel in the air.
yup my car does it as well. I believe its normal for a stock r34 gt-t diff. Mine still spins up two wheels with both wheels on the road. if it doesnt spin both wheels when they are both on the road then your lsd is fcked.
i think its just an issue with the limited suspension travel.
I can also confirm the driveway thing. It's a catch 22. You set your shocks to soft and then you drag your body kit.
On the topic of interchanging centers, I have a cusco 2 way for an S13 R200. Is it true this will fit my R34 housing?
ewww weldies!
once you go torsen or mechanical, you won't like weldies anymore... !
and yes like I said before, you're diff isn't stuffed, it's a marvellous diff, heaps better than the junk in R33 R32 GTS-ts
Put it on the track and you'll know what I mean when you hop into a R33 with a VLSD
  • 1 year later...
    • I was wondering about this. I'll do some research.
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
