stock is bulletproof, no need to change it, no gain and no advantage by changing, usually aftermarket ones are worse
if you want a loud noise, fit a pod filter and youll hear the bov on gearchange - ie the stock is loud with the right intake setup
https://www.sau.com.au/forums/topic/309984-bov-help/#findComment-5108678
Stock is best, as above no need to change unless you are making big power....
Externaly vented BOV's are for poses.... In the car noise like the waste gate is all you want... OWW what a sound, I so miss it.. Supercharger whine just not the same..lol
:P
https://www.sau.com.au/forums/topic/309984-bov-help/#findComment-5108793
is the stock one good for any power level.
https://www.sau.com.au/forums/topic/309984-bov-help/#findComment-5109237
I think the stock one starts leaking around 14psi
Anyone confirm this ?
My stock one was leaking at 16psi. I tried blocking the leak hole but it only held til 18psi. I ended up buying a GTR bov. It holds any boost level plus looks standard so you won't get defected for having it.
Just know that the GTR bov has a larger exit diameter than the GTSt bov. As a result, it won't fit directly onto the current return pipe.
You should find one easily in the For Sale section of the forums. I picked mine up for $50 + $10 p&h.
https://www.sau.com.au/forums/topic/309984-bov-help/#findComment-5110636
+ 2 for stock mine holding 12psi fine no worries
witch is really as a rule of thumb all the stock tubby can take unless you have it rebuilt with steal internals
The vta bovs are more then likely going to course you stalling issues and more hassle then what there worth
If you want the noise as already mentioned a apexi power flow sounds good
Not the best recording but you get the idea
https://www.sau.com.au/forums/topic/309984-bov-help/#findComment-5110668
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
