stock is bulletproof, no need to change it, no gain and no advantage by changing, usually aftermarket ones are worse
if you want a loud noise, fit a pod filter and youll hear the bov on gearchange - ie the stock is loud with the right intake setup
https://www.sau.com.au/forums/topic/309984-bov-help/#findComment-5108678
Stock is best, as above no need to change unless you are making big power....
Externaly vented BOV's are for poses.... In the car noise like the waste gate is all you want... OWW what a sound, I so miss it.. Supercharger whine just not the same..lol
:P
https://www.sau.com.au/forums/topic/309984-bov-help/#findComment-5108793
is the stock one good for any power level.
https://www.sau.com.au/forums/topic/309984-bov-help/#findComment-5109237
I think the stock one starts leaking around 14psi
Anyone confirm this ?
My stock one was leaking at 16psi. I tried blocking the leak hole but it only held til 18psi. I ended up buying a GTR bov. It holds any boost level plus looks standard so you won't get defected for having it.
Just know that the GTR bov has a larger exit diameter than the GTSt bov. As a result, it won't fit directly onto the current return pipe.
You should find one easily in the For Sale section of the forums. I picked mine up for $50 + $10 p&h.
https://www.sau.com.au/forums/topic/309984-bov-help/#findComment-5110636
+ 2 for stock mine holding 12psi fine no worries
witch is really as a rule of thumb all the stock tubby can take unless you have it rebuilt with steal internals
The vta bovs are more then likely going to course you stalling issues and more hassle then what there worth
If you want the noise as already mentioned a apexi power flow sounds good
Not the best recording but you get the idea
https://www.sau.com.au/forums/topic/309984-bov-help/#findComment-5110668
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
