  • 3 weeks later...
Taken from the Meguiers website:
Endurance Tyre Protectant Gel
Finally, a tyre protectant that lasts weeks, not days… even after rain and washing.
Endurance is a significant advancement in tyre protectant technology, providing a rich, dark "like new" look for weeks longer than you expect with ordinary protectants.
Endurance is a concentrated gel that saves you time and money by eliminating overspray, runs, drips, spotted driveways, messy cleanup and stained towels.By lasting longer, it also saves you money because it requires fewer applications.
An added bonus is that Endurance contains revolutionary antiozonants and protective polymers that help prevent browning from environmental elements.
This keeps your tyres looking true black.
No runs, overspray or stained driveways
Comes with special applicator
Available in 'natural look' and high gloss finishes
Now in 16oz/473ml size for even better value
It doesn't state anywhere in there about silicon, so I guess they must of had that previously but has now removed it from the contents.
I'll probably go and buy a bottle and compare it with what i got and see how we go.
Originally posted by JiMb0
Cool, any ideas how to get the black crap off my tyres that was put on at the auction yard in Japan ... it's like a sticky tar  substance .... not good ... I think next weekend I'll take each rim off one at a time and clean them down thouroughly with some degreaser.
JiMbO what is with the black tar shit that gets sprayed all over cars in japan? Check this 33 out, it also copped some on the front bumper.
I use the Meguiars Endurance stuff, and it's great.
Easy and quick to apply, comes with the applicator, no cleaning needed unless your tyres are that REALLY horrible brown/grey colour, and lasts ages!
Speaking of which, my car needs a wash and service (at least an oil and filter change)...
I just use 'auto king bumper and tyre spray' Its cheaper then the brand name stuff, its silicone spray so its naturally shiny, and wont do ****e to your tyres. If you really wanna get it off, just use wax and grease remover, no worries.
And BTW, that photo of the R33 with the black stuff on the bumper looks more like the car infront of it got started up, and blew a heap of rich running black fuel all over it...:D
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
