1. use common sense
2. search
the information is readily available on the forum, you can use any RB series powerfc. obviously you cant easily get one from another car and get it to work.
because all RB's are fairly similar electronically and the powerfc has the ability to be tuned, you can get a powerfc from any RB powered skyline to run any other. BUT, only the R33 and R34 powerfc will do the job PROPERLY. the R34 has variable cam timing, only the R33 and R34 powerfc has the components inside to run that. using a RB26 powerfc is cheaper but you need to redo your wirring harness and you lose control of the VCT.
the VCT (variable cam timing) is makes the car alot more powerful down low, without VCT the car will feel alot laggier unless you get a really good tuner to tune it out with adjustable cam gears.
the forum is FULL of information, more than you will find by asking questions and usually you can ask your question in a topic that is already going.
If you have any questions about how to search, please ask, if not I have armed you already with more than I should have.
Goodluck
1. use common sense 2. search the information is readily available on the forum, you can use any RB series powerfc. obviously you cant easily get one from another car and get it to work. because all RB's are fairly similar electronically and the powerfc has the ability to be tuned, you can get a powerfc from any RB powered skyline to run any other. BUT, only the R33 and R34 powerfc will do the job PROPERLY. the R34 has variable cam timing, only the R33 and R34 powerfc has the components inside to run that. using a RB26 powerfc is cheaper but you need to redo your wirring harness and you lose control of the VCT. the VCT (variable cam timing) is makes the car alot more powerful down low, without VCT the car will feel alot laggier unless you get a really good tuner to tune it out with adjustable cam gears. the forum is FULL of information, more than you will find by asking questions and usually you can ask your question in a topic that is already going. If you have any questions about how to search, please ask, if not I have armed you already with more than I should have. Goodluck
THANKS FOR INFORMATION. NORMALY I WOULD DO AN EXTENSIVE SEARCH BUT WHEN I TRYED ALL I GOT WAS A POST ABOUT STEP 1 AND STEP 2 ON UPGRADING. IM ON MY PHONE AT WORK SO THE PAGE LOAD TIME IS LIKE 10MIN.S SO I FIGURED ASKING THE QUESTION WOULD BE QUICKER THAN TRYING TO SEARCH WITTH THE SLOW PHONE SPEED
When you get home, follow these two links http://www.skylinesaustralia.com/forums/Fa...req-t64201.html http://paulr33.skylinesaustralia.com/docs/...erfc-faq.htm#55 just about everything you could want to know about powerFC
THANKS MATE WILL  DO (ONLY FOUR HOURS OF THIS SHIFT LEFT GOTTA LOVE NIGHT SHIFT).
lol better hope ur getting paid well, im going 2 bed :blush:
YEAH PAY.S GOOD BUT THE WIFES PUT HER FOOT DOWN AND SAID SHE LET ME GET THE CAR I WANT BUT NO UPGRADES TO THE CAR TILL SHE GETS THE UPGRADES TO THE HOUSE :D ONE DAY !!!!!!
lol then buy the car with the upgrades already and tell her ur saving up for the house... "its not like i dont want to work on the house hun, afterall once im done i can work on the car too :D"
mediation, atleast they think so :blush:
    • Updated with the latest <68mm Xona Rotor turbos.  The two XRA options are on paper some of the compressor performance I've seen
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
