hey guys, in need of a new steering wheel. must be in decent condition.
not fussed if its the stock R33 one or a non factory steering wheel.
let me know what ya got
oh and not looking to spend a whole lot as can borrow a mates if needed.
https://www.sau.com.au/forums/topic/310033-steering-wheel-for-r33/
