Isnt the top of the piston (around ring land/top ring) usually about 40 thou smaller then the skirt? Or does that part expand so much that it uses up the extra clearance whilst running at operating temps?
Maybe im wrong, I was always under the impression that piston size is based off skirt diameter...
Unless I worked that out incorrectly, thats only 2.8 thou of clearance. I assume the piston size is 87mm at the skirt? .07 is only .0028" Unless your measuring devices are not accurate enough???
What if the piston to bore was too tight, not too excessive? Would the rubbing show up much the same? or would it be in four corners instead of just two?
When I measured my wiseco's last night, I measured the top of the piston above the top compression ring. This came out at exactly 2.5 thou under 87mm, so with a 87mm bore it would have the correct piston to bore clearance.
Same with the old CP's. The top of the piston came out like 3 thou under 87mm. So they have put 2.8 thou over on the bore as you say, but more than likely 3 because I only had vernier calipers to measure with and there was a very slight carbon lip on the top of the bore. Plus the pistons were already 3 thou under 87 which obviously gives you in the area of 6 thou clearance.
Above the top compression ring was polished, which someone else mentioned as a tell tale sign.
I think that is what happend, I work in I.T. for a living so feel free anyone with more knowledge to chime in, but I think that's everyone's general line of thought.
Great question, I was just thinking this also.
did it rattle when cold?
if you pull all the rings off the pistons, slide one in. you shouldnt be able to flop it around in the bore.
or you could compare it with your new ones. by feel. not at all acurate but you will be able to see if one is tighter..
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
    • @Dose Pipe Sutututu I read your replies RE: R35 GTR MAFs, any ideal spots to put on? Obviously will need the adapter plate. Will be having a cross over intercooler fitted shortly, would putting it a bit before the TB be okay?
