Isnt the top of the piston (around ring land/top ring) usually about 40 thou smaller then the skirt? Or does that part expand so much that it uses up the extra clearance whilst running at operating temps?
Maybe im wrong, I was always under the impression that piston size is based off skirt diameter...
Unless I worked that out incorrectly, thats only 2.8 thou of clearance. I assume the piston size is 87mm at the skirt? .07 is only .0028" Unless your measuring devices are not accurate enough???
What if the piston to bore was too tight, not too excessive? Would the rubbing show up much the same? or would it be in four corners instead of just two?
When I measured my wiseco's last night, I measured the top of the piston above the top compression ring. This came out at exactly 2.5 thou under 87mm, so with a 87mm bore it would have the correct piston to bore clearance.
Same with the old CP's. The top of the piston came out like 3 thou under 87mm. So they have put 2.8 thou over on the bore as you say, but more than likely 3 because I only had vernier calipers to measure with and there was a very slight carbon lip on the top of the bore. Plus the pistons were already 3 thou under 87 which obviously gives you in the area of 6 thou clearance.
Above the top compression ring was polished, which someone else mentioned as a tell tale sign.
I think that is what happend, I work in I.T. for a living so feel free anyone with more knowledge to chime in, but I think that's everyone's general line of thought.
Great question, I was just thinking this also.
did it rattle when cold?
if you pull all the rings off the pistons, slide one in. you shouldnt be able to flop it around in the bore.
or you could compare it with your new ones. by feel. not at all acurate but you will be able to see if one is tighter..
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
