West Posted January 2, 2004 Share Posted January 2, 2004 Hi all, Just want to know if after market LSD make sort of tiny metal cracking noise when take off, anyone had or have experience with aftermarket LSD? Thanks. Link to comment https://www.sau.com.au/forums/topic/31004-after-market-lsd/ Share on other sites More sharing options...
meggala Posted January 3, 2004 Share Posted January 3, 2004 yea they can make a clicking sound this means they are very tight. Link to comment https://www.sau.com.au/forums/topic/31004-after-market-lsd/#findComment-625948 Share on other sites More sharing options...
West Posted January 3, 2004 Author Share Posted January 3, 2004 Thanks Meggala so does that means good or bad? What does it actuallly do...ect....as i've had no idea what they are for? Also can it be normal/standard Lsd with aftermarket internal? Thanks Link to comment https://www.sau.com.au/forums/topic/31004-after-market-lsd/#findComment-626119 Share on other sites More sharing options...
Al Posted January 3, 2004 Share Posted January 3, 2004 Did you get it with the car, or have you recently bought it? Link to comment https://www.sau.com.au/forums/topic/31004-after-market-lsd/#findComment-626826 Share on other sites More sharing options...
drifto Posted January 3, 2004 Share Posted January 3, 2004 I had a modified R200 diff in my 32 gts and it would click as it was nearly at the point of locking. This usually happens when doing slow speed tight turns under very light throttle. I put the stock R180 back in and apart from it not having much limo effect any more it also clicks but no where near as loudly. These are normal sounds from any mechanical LSD that uses dry clutch plates instead of a viscous fluid to lock the centre under load. They are adjutable by simply putting more shims in the centre to tighten the clutches. Just go the mini spool it's much better Link to comment https://www.sau.com.au/forums/topic/31004-after-market-lsd/#findComment-626912 Share on other sites More sharing options...
West Posted January 3, 2004 Author Share Posted January 3, 2004 Got it with the car. Link to comment https://www.sau.com.au/forums/topic/31004-after-market-lsd/#findComment-627358 Share on other sites More sharing options...
Duncan Posted January 4, 2004 Share Posted January 4, 2004 Hey West, The clicking noise is the inside wheel skipping forward in tight turns. The diff locks up forcing the inside wheel to move at the same speed as the outside wheel. The internals of the diff are swapped into the stock diff housing so that the driveshafts, tailshaft etc aren;t affected. Link to comment https://www.sau.com.au/forums/topic/31004-after-market-lsd/#findComment-628137 Share on other sites More sharing options...
Al Posted January 4, 2004 Share Posted January 4, 2004 Just asked because i am looking for a Mechanical 2-way LSD diff, myself. Link to comment https://www.sau.com.au/forums/topic/31004-after-market-lsd/#findComment-628582 Share on other sites More sharing options...
Roy Posted January 5, 2004 Share Posted January 5, 2004 Are you sure its the diff? Can you descibe the noise almost like a small ball bearing being dropped into a heavy still tin? Reason i ask is that im pretty sure my car has a std diff, and from the day i bought the car it makes this slight click noise when i take off from stationary. Had it checked out a few times and two mechanics havce said its fine. Mayve CV noise??? If it were the mech diff making the noise as a few have mentioned, wouldnt you feel the diff locking up with the chassis crabbing a little??? Link to comment https://www.sau.com.au/forums/topic/31004-after-market-lsd/#findComment-628841 Share on other sites More sharing options...
meggala Posted January 5, 2004 Share Posted January 5, 2004 good point actually roy my cefiro had a similar problem and it was a uni joint get that checked as well west cheers Link to comment https://www.sau.com.au/forums/topic/31004-after-market-lsd/#findComment-628860 Share on other sites More sharing options...
fatz Posted January 5, 2004 Share Posted January 5, 2004 mmmm two way sld drool i should get me one Link to comment https://www.sau.com.au/forums/topic/31004-after-market-lsd/#findComment-628897 Share on other sites More sharing options...
Guest INASNT Posted January 5, 2004 Share Posted January 5, 2004 I got the same diff west and make the same noises and has done so for the last 3. When i first got it i thought the diff was stuffed but after talking to a few people found out it was normal Link to comment https://www.sau.com.au/forums/topic/31004-after-market-lsd/#findComment-628952 Share on other sites More sharing options...
