Hi all, I'm trying to install a new satnav head unit into my car, but have a few issues that are cropping up and hoping the guru's here could help me out.
Firstly, where can I find the reversing lamp wire for the reverse gear input? Is it located on the passenger side or drivers side footwells?
Secondly, when connecting the speed sensor input, the manual doesn't specify what sort of signal is required and the ecu signal is different from the dash speedo signal, which one do I use? Would either one cause issues?
Lastly, I wired everything else up and went to test the system, no issues other than there is no sound coming through the speakers... before I go ripping apart all the soldering that's been done, there are a couple things that I thought might have caused the issue. I'm not 100% sure the grounding point I used (I used the metal bracketing behind the dash), is there a better place to use a ground point or would this even be the trouble with this? The head unit also has no input for "Amplifier on" in the wiring harness, so I blanked out that wire coming from the aerpro harness. I'm guessing this is the most likely cause of the problem, but I've scoured the device manual and it has no mention of any wiring to connect this particular wire to.
Anyone able to give some advice on these?
https://www.sau.com.au/forums/topic/310049-r34-stereo-install-questions/
Firstly, where can I find the reversing lamp wire for the reverse gear input? Is it located on the passenger side or drivers side footwells? Usualy runs from the gearbox to the boot
Secondly, when connecting the speed sensor input, the manual doesn't specify what sort of signal is required and the ecu signal is different from the dash speedo signal, which one do I use? Would either one cause issues? hmm curly one , what model satnav??
Lastly, I wired everything else up and went to test the system, no issues other than there is no sound coming through the speakers... before I go ripping apart all the soldering that's been done, there are a couple things that I thought might have caused the issue. I'm not 100% sure the grounding point I used (I used the metal bracketing behind the dash) OK in my 33 but test with a multimeter, is there a better place to use a ground point or would this even be the trouble with this? The head unit also has no input think you mean output here, use antenna triger instead for "Amplifier on" in the wiring harness, so I blanked out that wire coming from the aerpro harness. I'm guessing this is the most likely cause of the problem, but I've scoured the device manual and it has no mention of any wiring to connect this particular wire to.
cheerz
that will do part of it. the rev wire is on the drivers side. as for no sound - if its an R34 and you have the holographic sound system - its AMPLIFIED! now hopefully you DID NOT butcher the harness. if so you haev screwed yourself. (I know the positions but not the wiring.)
cheerz
Cheers :down:
Any idea if the wire in the cabin or under the car?
The satnav is a AVIC-F900BT
Whoops I meant output. Bit more info about what's on the harness below:
Macross
just stumbled on 2 this might help
Linky bit
I did have a look at this but was unsure with how to pull the fusebox out, so wanted to check if there was another method. Will take a gander around the rev wire to see what I can swing.
Definately haven't butchered the wiring harness as anything I was unsure about I simply used some shrink wrap to cap off the end of the wire. Stupidly, I just realised my mistake, when I was wiring up the harness everything matched up perfectly, except for the amplifier on wire (which I mentioned I capped off) however there is a second harness (with rca plugs) that has a "system remote control" wire, which I can now see is used to power up the amp, so I can see where to connect that wire to now.
Cheers for the help all :)
Macross
there doesn't seem 2 be much solid info on these satnavz, seem to have lots of begs though
given that the speed wire is a signal rather than power I'd expect less that 100mA current flow,
therefore you should be safe if you put a 100mA or similar fuse inline with the speed sig (I'd start with the ecu signal - easy access)
cheerz
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
    • shit boxes, kids, and daily drivers are all welcome
