I have a 1999 Stagea RS4 Auto
My drivers window auto up and down only works sometimes?
The switch always works - window will always go up or down. ( when you only use the first click of the switch)
But if you go the second click (so you dont have to hold the button) only seems to work randomly.
faulty switch, realy box? maybe but the randomness of it just seems weird for a faulty part.
Is this a comon faul? heppend to anyone else? Or is it something im going to have to start pulling stuff
apart to work out?
Secondly, I have this silly little gizmo under my dash, LH side of the steering column, no idea what it is
or what if dose, here is a pic of it, anyone seen one before or know what it is?
Has wiring and some sort of elec box connected to it. My thoughts some sort ot servicing warning device?
Here is the pic
Pic
Oz
https://www.sau.com.au/forums/topic/310090-stagea-questions/
apart to work out?
Here is the pic
Pic
Oz
When you find out the problem with the window let me know. Ours has the same fault, we just live with it
yeah the window is just the switch . pull it apart , i mean right apart . if your keen . or get another switch from the wreckers if your not
Just the randomness of it dose not seem like a faulty part. But I guess its time to pull something apart.
Will report on findings if i get any :D
Oz
Edited by Ozzyla
    • If I had "perfect R33 GTR" kinda money I would have bought one of the crazy expensive low mileage HJA cars, but I am sadly not that wealthy. I already picked this car out of various Skylines for sale locally, most of which were worse in some way. Only a few cars were actually better but also more expensive. In terms of buying a motor locally, I at least have the option to inspect it myself and juding the seller as a person, and used or freshly rebuilt engines that some people sell are actually ok price-wise. I knew the car was going to require work, but shit piled up real fast and I haven't even driven 1000km yet as the turbo started oiling like a bitch within a few weeks after I got the car.   I assume it wasn't actually me who cracked it, though there is no way to know when that crack formed and if the previous owner even knew it was there. Buying another 05U Block can be a gamble, yeah, but the cheapest PRP cast block is like twice or more money-wise, and billet is 3 or 3 times as much. For now I am most likely just keeping the current engine, as a rebuild or engine swap isn't happening right now. But I am seriously considering buying a second engine and selling mine in return. Might be a sweet deal at the end.
    • Hi all. I need some help buying the correct size banjo bolts for my 2860 turbos. Because whoever installed them tore up the original part, I ordered new ones of this kind, because I just figured these were the most leak-resistant option as I already had trouble with a shitty braided line. I need to know the thread size of the smaller left hole, that is the turbo oil feed connection. I found out so far that the turbo oil inlet apparently has a 7/16"-24 thread, but I cannot find any listing or description of the thread size on this line. I do not have the original bolts. I tried using the bolts that were in the turbos (the ones that were mounted with the shitty braided line) but they sit very loosely so they can't be the right thread. Means either these bolts are the wrong ones (how do they fit the turbo then? no clue) or the wraparound-lines have a different thread than the turbo oil feed itself. Help is appreciated, asking Nissan directly is obviously not going to work.
    • EDIT: PSA to whoever stumbles upon this thread. It is in fact a crack in the block that caused this concern. Just letting you know. In my case, a few cm long hairline crack going horizontally above the turbo oil feed. Classic RB shit I guess
    • Might as well pop in some cams, head gasket, head studs, and a flex sensor. Full send.
