Hey all my first post!!! had a quick search couldnt find what i was after, I am curious to know how strong the ceramic wheeled turbos that come stock with my GTR??
What amount of 'torture' can they withstand??
And also what are some of your opinions of the ARC super induction box??
thanks
nick
https://www.sau.com.au/forums/topic/310093-stock-r33-gtr-turbos/
std ceramic exhaust wheel like the other gtr ones
it may fail if you go over 12psi ish
if it fails, it can kill the engine
So would it be better to leave on standard boost and save up for new turbos??
Say N1s or GTSS or garret equivalent
Edited by levinboy
If you go R34 GTR N1's, they are pretty much the equivalent to HKS GTSS, different Compressor Housing and Compressor Wheel.
Specs wise is very similar, but max power output is approx:
N1's = 367.75 kW
GTSS = 411.88
... From memory.
N1's = 367.75 kW
GTSS = 411.88
... From memory.
WRAOWNG - Neg.
2860-7s ARE r34 N1s and 2859-9s are HKS GTSS without actuators (i believe 2859-1 are the same with the actuators attached or get -9s and use ur stock actuators)
N1s are not GTSS, they are 2 different turbos.
N1s are alot like stock but stronger as not ceramic, go the GTSS (-9)
WRAOWNG - Neg.
Ah yeah!
Fuck, I over looked that on my turbo chart.
Thanks.
BTW there are 3 Spec of R34 GTR N1's :P
I just compared the specs and they were quite similar but the GTSS and -7's are pretty much inline ball with each other... Like you said.
GTR R34N1 (14411-AA403)
GT22 / C106 / 44.5 - 60.0 / 55T / 0.42 / T25 / GT25 / 42.4 - 53.8 / 62T / 0.64 / Ball Bearing.
Garrett 707160-7
GT25 / GT25 / 44.5 - 60.0 / 55T / 0.42 / GT25 / GT25 / 42.4 - 53.8 / 62T / 0.64 / Ball Bearing.
HKS GT-SS
T04B / GT25 / 44.46 - 59.41 / 56T / 0.42 / T25 / GT25 / 42.4 - 53.85 / 62T / 0.64 / Ball Bearing.
  • Like 1
lol that i did not know!
post it up
34N1 (14411-AA401)
T3 / C106 / 44.5 - 60.0 / 55T / 0.6 / T25 / GT25 / 42.4 - 53.8 / 62T / 0.64 / Ball Bearing.
34N1 (14411-AA402)
34N1 (14411-AA403)
Pretty much the same but the Compressor Housing and the Compressor A/R are different.
http://homepage.ntlworld.com/tbroom/Turbos.htm
:P
  • 3 years later...
Stock R34 GTR turbos run around 0.8 bar boost with restrictor in. With boost restrictor removed they run about 1 bar. On the ball bearing turbos 1 bar is fine.
Problem is, most people think their boosted 'genuine' 60,000km gtr will withstand 1 bar forever... Only to realise the Turbos have done more like '160,000' km's after they go bang.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
