hi all
sean here from townsville , im the owner of an 89 sillhouette series 3 that i have owned for about 7 years now .
currently it is the need of a paintjob and some dents and panel repairs but it is still road worthy and drives not too bad for an old girl with over 500k on the clock ,
it has 15" mags
king street springs as they said i couldnt buy any lower than that lol
extractors im not sure what size but descent amd a full 3" mild steel with racing 3" cat and cannon with 4" outlet , no mufflers or hotdogs thats it and it rumbles i can assure you lol
its 5 spd and i have replaced the clutch with street clutch but soon to upgrade to something to handle torture as it will have drag suties again soon ,
in the cupboard i have a Haltech e6-x computer
stainless highmount manifold
turbo rated about 450hp and 50mm wastegate
im looking for a set of injectors to suit this setup 440cc or 550cc topfeed would be good if anyone can help me
[email protected] is my email address if you could contact me and i will chat to you more about this all , also ii am in need of an intercooler setup tp suit this car if you can direct me to a package or to someone who c an help me that would be great too ...
https://www.sau.com.au/forums/topic/310110-newbie-from-tville/
    • Looking at finally painting and installing my R32 GTR wing I bought back in 2018. I got two quotes: Quote 1: $880 includes: wing, spare boot, holes welded up prep/paint. Pro: full boot with wing AND hole-less boot with lip i can swap between Con: $$  Quote 2: $330 wing only. Pro: cheaper Con: lose my (relatively) rare no holes sedan boot Also to consider I do plan on painting my whole car at some point "soon" (been saying that since 2018) Anyway Enjoy these All Japan Day 2025 pictures of my 4 door, still rocking the Calsonic Livery! Rolling in Interior shot Matching Peer Pressure Racing overalls are pretty cute ngl. This year was a hard 1990 cut so I got to be over with all the older cool stuff Next to arguably the best car there. A mighty S-Cargo
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
