Just wondering if anyone has a say on the Return Flow type FMIC that are popping up all over the place?
I have been searching around for a decent sized FMIC without going over the top and these have caught my eye due to the fact of no need to cut my REO bar or any other nasty holes in my baby.
Only problems I can see with them at a glance is the fact the return pipe sits VERY low and that nasty bend they often have towards the end of the return pipe. And possibly the sharp change of direction for the air to have to go back towards the turbo.
Just incase I didnt explain it well enough heres a pic of the kit im interested in.
Anyone got some more info on these?
https://www.sau.com.au/forums/topic/310124-return-flow/
  • Replies 40
If you 're worried about how much power you can achieve, you shouldn't be.
My car made 250rwkw with one of these, plus, it has excellent response - meaning that the curvature of the return pipe still allows the air to achieve a smooth flow. The one in the pic is a blitz so it should be fairly efficient.
https://www.sau.com.au/forums/topic/310124-return-flow/#findComment-5110147
i have one of these...
you will probably have to trim your reo a bit, but it's a small price to pay for not having to attack your inner guard with a hole saw!
also re the height clearance, the core is smaller than the usual aftermarket coolers out there, so it doesn't sit ridiculously low (there are only a few light scuffs on mine, in contrast to my mashed up front bar)
do recommend something like this :P
https://www.sau.com.au/forums/topic/310124-return-flow/#findComment-5110151
Not worried about power since I know that beautiful Blitz would flow more than what a RB20 would ever make, just trying to find out info about them from anyone who has one.
Response is all Im after at the end of the day, and Im leaning towards the Blitz ATM due to the fact its only $780 and its Blitz so you know its quality. Or a HPI kit of the same style.
https://www.sau.com.au/forums/topic/310124-return-flow/#findComment-5110155
i currently have a black Blitz return flow on my R33, makes an easy 255rwkw, with the cooler having plenty more left in it. A few people have said they pushed 300rwkw through good quality return flow coolers.
As you said Blitz generally make good stuff, so buy it and enjoy it!!!!
https://www.sau.com.au/forums/topic/310124-return-flow/#findComment-5110232
Thanks heaps for all the replies guys, just the sort of feed back I was looking for.
Also for the ARC side mount, what sort of power would they be able to handle and not really hit its limits? Trying too make sure all the supporting mods are capable of handling much more than what I want to get out of the engine.
Chasing around 300rwhp with as much response as possible.
EDIT - Holy hell just had a quick search for the ARC SMIC for a HCR32 just under $1200, think I'll be sticking with the Blitz at a much more pocket friendly $780
Edited by R32 DORI DORI
https://www.sau.com.au/forums/topic/310124-return-flow/#findComment-5110405
I bought a blitz cs kit and even though i not the most mechanicly minded i still could fit it. I did have to take a fair bit off the stock bumper as you could see. ( better than chopping your chasis though )
Edited by Kenna802
https://www.sau.com.au/forums/topic/310124-return-flow/#findComment-5110854
yes you have to trim the reo to fit the Blitz LM/CS.
And no, the return pipe doesn't sit low. Mine is higher than the factory lip.
And, the flow actually goes through the bottom pipe 1st and then swings into the FMIC :down: Not the other way around. (not that it matters.. just saying :P )
https://www.sau.com.au/forums/topic/310124-return-flow/#findComment-5110944
Would rather shave the front bar than anthing else. Looks really nice though, pretty much what im looking for, even though the FMIC will be blacked out before it goes in <3 Sleepers.
https://www.sau.com.au/forums/topic/310124-return-flow/#findComment-5110954
I always thought about blacking my Blitz out too.. im scared, if i dont like it its kinda hard to go back again..
Whats the saying? 'once you go black you never go back' lol
Im not worried about going back, Black R32 on Black rims. Keeping as low profile in the crowd as possible, not that the Bright red stove tops dont give it away every single time at night.
Plus what it more sexy than a blacked out skyline?
https://www.sau.com.au/forums/topic/310124-return-flow/#findComment-5110967
ARC is expensive because it is high quality japan made
not paying out blitz but yeah ARC make good products
For the power Im chasing I doubt I would see any difference between ARC or Blitz, or even a cheap Cooling Pro FMIC at these levels.
ARC do make brillant products but they are still very pricey, not too fond of paying big just for a name...other than the ARC Airbox. More than happy to fork out the 400 bucks for one of them.
On a side note, anyone know off hand if QLD comes under the same sort of rulings for intake mods as Vic? currently have a pod filter with a custom heat sheild made up.
https://www.sau.com.au/forums/topic/310124-return-flow/#findComment-5110974
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
